Hi, I had to transform an SOPC bilder System created in Quartus 9.1 to a Qsys System in Quartus 12.1SP1 ...
But now I'm running into a very frustrating issue with qsys ... I hope I'm missing some simple thing. The problem is I have a sysq-system and I use schematics as the top level so I create a symbol file of course from qsys and instantiate it at the top level ... Now, when I do some modification in the Qsys and regenerate and subsequently update the symbol then all pins get randomly changed to differnt locations in the symbol ... How can I fix this? It is most annoying to shuffle all pins again to the right pins!!! SOPC never did this before!!! I need to fix this problem because I suppose that I'll have to insert more other PIO and ports and I can't change the schematics connection everytime!!! Help me! Thanks!Link Copied
You cant stop this. THe only workaround would be to do the top level in HDL and use named association.
I have the same Problem with .bsf generation in QSYS v.12.1sp1 ... I had a .bsf built with QSYS v.11.1sp2, which looked quit usable After compilation with 12.1sp1 everything was scrambled :mad: The old 11.1-bsf begins with...
(header "symbol" (version "1.2"))
(symbol
(rect 64 64 384 1512)
(text "fpga_backup" (rect 148 -1 234 15)(font "Arial" (font_size 10)))
(text "inst" (rect 8 1432 25 1444)(font "Arial" ))
(port
(pt 0 72)
(input)
(text "clk_clk" (rect 0 0 37 14)(font "Arial" (font_size 8)))
(text "clk_clk" (rect 4 61 41 75)(font "Arial" (font_size 8)))
(line (pt 0 72)(pt 128 72))
(port
The new one (v12.1) begins with ...
(header "symbol" (version "1.1"))
(symbol
(rect 0 0 512 1448)
(text "fpga" (rect 244 -1 261 11)(font "Arial" (font_size 10)))
(text "inst" (rect 8 1432 20 1444)(font "Arial" ))
(port
(pt 0 72)
(input)
(text "in_port_to_the_data_link_irq" (rect 0 0 113 12)(font "Arial" (font_size 8)))
(text "in_port_to_the_data_link_irq" (rect 4 61 172 72)(font "Arial" (font_size 8)))
(line (pt 0 72)(pt 224 72)(line_width 1))
Is it possible that QSYSv12.1 uses an older bsf-generator ??? The bsf-syntax seems to be quite simple, so it shouldn't be a big issue to build a TCL-script, which makes a .bsf looking like the good old SOPC-symbols :-) I haven't found a documentation of the .bsf syntax so far. So I tried to comment my automatically generated one.... ...
(symbol
(rect x1 y1 x2 y2) --> the rectangle for the symbol
(text "<title>" (rect ....)(font "...")) --> Title of the QSYS-System
(port
(pt x y) --> coordiates of the connection point
(input)
(text "...." (rect 0 0 x y)(font "...")) --> ?? ist it the signal name of the port
(text "...." (rect x1 y1 x2 y2)(font "...")) --> Text which appears as node name
(line (pt x1 y1)(pt x2 y2)(line_width 3) --> line to the port (Bus has line_width 3)
(port
maybe I've to play around a bit... ... but maybe somebody already has done it :) Regards,
Not quite what you're looking for, but the SOPC Builder "version 1.1" format is produced by the Perl script in sopc_builder/bin/mk_bsf.pm Yes it looks pretty simple.
An alternate way to work around this problem is to use Quartus to produce your own .bsf file from a modified copy of your Qsys top-level .v or .vhdl file. In other words, create a copy of the top-level HDL file, modify the ordering of the ports, and then use Quartus File->Create/Update->Create Symbol for Current File... to have Quartus parse and generate a new .bsf from your modified file. You would only have to repeat this process each time you change the ports included in the top level Qsys.
