17120 Discussions
Quartus 17.1 What does this error message mean?
Problem Details
Error:
Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_algorithm.cpp, Line: 1109
Illegal tap position
Stack Trace:
0x4f38e: PGME_ALGORITHM::get_id_index + 0x6e (pgm_pgme)
0x516fb: PGME_MAXII_ALGORITHM::get_open_ids + 0xab (pgm_pgme)
0x5611c: PGME_MAXII_ALGORITHM::init + 0x70c (pgm_pgme)
0x37c62: PGME_PROGRAMMER::engage + 0x1162 (pgm_pgme)
0xd425: MDB_FILE_NEW_DLG::OK_clicked + 0x75 (sys_mdb)
0x295b7: QThread::start + 0x427 (QtCore4)
0x24f7e: _beginthreadex + 0x106 (MSVCR120)
0x25125: _endthreadex + 0x191 (MSVCR120)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus Prime Version 17.1.0 Build 590 10/25/2017 SJ Lite Edition
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 17.1.0
Build: 590
Edition: Lite Edition
This means Quartus has crashed. You may need to raise a mysupport ticket to find out why.
you can also check your system logfiles. You might find something there. Is it a reoccurring error or just a one-off.
--- Quote Start ---
--- Quote End ---
It error always happens in the versions 16.0, 17.1.
After this error, I need to restart my computer because the USBblaster does not work after that.
Quit Quartus and trash the db and incremental_db folders for your project. You'll need to recompile, but this might fix the issue.
You may also need to reinstall USB Blaster drivers.
--- Quote Start ---
--- Quote End ---
You didn't actually tell when it happens, e.g. compiling a specific project, in which phase, etc.
--- Quote Start ---
--- Quote End ---
This is usually indicating that part of Quartus is still running. To terminate it without restarting Windows, you can use the task manager.
If I program separately, everything is programmed correctly and works.
If all four together, then a complete collapse occurs.
