17003 Discussions
Quartus 20.1 - tri state output bad generated code
lusant
I'm new in FPGA world.
To learn a bit more fast, I bought one kit with Cyclone IV E EP4CE6E22C8.
I've found some software examples for that kit, but the programming language is Verilog. As I started with VHDL, I've found a converter software (Icarus Verilog ) to translate the Verilog tp VHDL, which seams to work fine (with some limitations, but it does the job).
One of the statements is translated to the following concurrent statements:
sda <= sda_r when sda_link = '1' else tmp_ivl_0;
tmp_ivl_0 <= 'Z';
The sda output should be a tri state.
With the lines above, Quartus will give the following warnings :
Warning (13009): TRI or OPNDRN buffers permanently enabled
Warning (13010): Node "sda~synth"
And generate the following hardware connections:
As the "sda" output must be tri state, in this conditions, the FPGA don't do the job as it should.
If I change the code lines to the following:
  sda <= sda_r when sda_link = '1' else 'Z'; --tmp_ivl_0;
 The warning goes away and the connections generated are:
In this situation the FPGA acts like it should.
My questions are:
Why those concurrent statements are not translated like it should and I need to assign the 'Z' value directly in the "else" part ?
Is this a bug of Quartus or a lack of my VHDL knowledge ?
Thanks for your feedback.
sstrell
The extra signal in there does not synthesize to a tri-state I/O correctly.  It depends on the device architecture, but assigning the Z directly like you do in the second example is required for Quartus to interpret it correctly, setting sda_link, in this case, as the OE.
sstrell
lusant
Thanks for the clarification @sstrell .
I know there is a lot to learn in this stuff, but I was expecting less tricky things.
