17252 Discussions
Quartus 21.1 HPS DDR3 SDRAM Compile Error
sphilipp
I get errors when compiling my CycloneV HPS using DDR3 SDRAM IP with UniPhy.
The project compiled well under Quartus 18.1
After correctly installing WLS using Ubuntu, updating ubuntu and apt-installing packages wls, make and dos2unix, I succeeded to upgrade to Quartus 20.1, but upgrading to Quartus 21.1 ist still a problem.
I already verified the location of my temp drive to be local, which I read in another post.
The error message is:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/eda/intelfpga/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/eda/intelfpga/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: /mnt/c/eda/intelfpga/21.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../hps_AC_ROM.hex -inst_rom ../hps_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000100001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100100000 -DAC_ROM_MR1=0000000000000 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000001000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001000001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011000000 -DAC_ROM_MR1_MIRR=0000000000000 -DAC_ROM_MR2_MIRR=0000000100000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: UniPHY Sequencer Microcode Compiler
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Copyright (C) 2021 Intel Corporation. All rights reserved.
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Reading sequencer_mc/ac_rom.s ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Reading sequencer_mc/inst_rom.s ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing ../hps_AC_ROM.hex ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing ../hps_inst_ROM.hex ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing sequencer/sequencer_auto_ac_init.c ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
Error: border: Execution of script generate_hps_sdram.tcl failed
Error: border: 2022.01.26.09:55:09 Info:
Error: border: ********************************************************************************************************************
Error: border:
Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
Error: border:
Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: border:
Error: border: 2022.01.26.09:55:15 Warning: Ignored parameter assignment device=5CSEMA6U23I7
Error: border: 2022.01.26.09:55:15 Warning: Ignored parameter assignment extended_family_support=true
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram: ODT is disabled. Enabling ODT (Mode Register 1) may improve signal integrity
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.seq: This module has no ports or interfaces
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.c0: ODT is disabled. Enabling ODT (Mode Register 1) may improve signal integrity
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.p0: p0.scc must be exported, or connected to a matching conduit.
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.as: as.afi_init_cal_req must be exported, or connected to a matching conduit.
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.as: as.tracking must be exported, or connected to a matching conduit.
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.c0: c0.status must be exported, or connected to a matching conduit.
Error: border: 2022.01.26.09:55:25 Warning: hps_sdram.p0: p0.avl must be connected to an Avalon-MM master
Error: border: 2022.01.26.09:55:25 Info: hps_sdram: Generating altera_mem_if_hps_emif "hps_sdram" for QUARTUS_SYNTH
Error: border: 2022.01.26.09:55:31 Info: pll: "hps_sdram" instantiated altera_mem_if_hps_pll "pll"
Error: border: 2022.01.26.09:55:31 Info: p0: Generating clock pair generator
Error: border: 2022.01.26.09:55:33 Info: p0: Generating hps_sdram_p0_altdqdqs
Error: border: 2022.01.26.09:55:45 Info: p0:
Error: border: 2022.01.26.09:55:45 Info: p0: *****************************
Error: border: 2022.01.26.09:55:45 Info: p0: Remember to run the hps_sdram_p0_pin_assignments.tcl
Error: border: 2022.01.26.09:55:45 Info: p0: script after running Synthesis and before Fitting.
Error: border: 2022.01.26.09:55:45 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
Error: border: 2022.01.26.09:55:49 Error: seq: Error during execution of "{C:/eda/intelfpga/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: 2022.01.26.09:55:49 Error: seq: Execution of command "{C:/eda/intelfpga/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: 2022.01.26.09:55:49 Error: seq: /mnt/c/eda/intelfpga/21.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../hps_AC_ROM.hex -inst_rom ../hps_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000100001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100100000 -DAC_ROM_MR1=0000000000000 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000001000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001000001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011000000 -DAC_ROM_MR1_MIRR=0000000000000 -DAC_ROM_MR2_MIRR=0000000100000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1
Error: border: 2022.01.26.09:55:49 Error: seq: UniPHY Sequencer Microcode Compiler
Error: border: 2022.01.26.09:55:49 Error: seq: Copyright (C) 2021 Intel Corporation. All rights reserved.
Error: border: 2022.01.26.09:55:49 Error: seq: Info: Reading sequencer_mc/ac_rom.s ...
Error: border: 2022.01.26.09:55:49 Error: seq: Info: Reading sequencer_mc/inst_rom.s ...
Error: border: 2022.01.26.09:55:49 Error: seq: Info: Writing ../hps_AC_ROM.hex ...
Error: border: 2022.01.26.09:55:49 Error: seq: Info: Writing ../hps_inst_ROM.hex ...
Error: border: 2022.01.26.09:55:49 Error: seq: Info: Writing sequencer/sequencer_auto_ac_init.c ...
Error: border: 2022.01.26.09:55:49 Error: seq: child process exited abnormally
Error: border: 2022.01.26.09:55:49 Info: seq: "hps_sdram" instantiated altera_mem_if_hhp_ddr3_qseq "seq"
Error: border: 2022.01.26.09:55:49 Error: Generation stopped, 3 or more modules remaining
Error: border: 2022.01.26.09:55:49 Info: hps_sdram: Done "hps_sdram" with 7 modules, 38 files
Info: border: "hps_io" instantiated altera_interface_generator "border"
Error: Generation stopped, 1 or more modules remaining
Info: e090_hps: Done "e090_hps" with 54 modules, 131 files
Error: qsys-generate failed with exit code 1: 60 Errors, 5 Warnings
Info: Finished: Create HDL design files for synthesis
Any help would be appreciated.
Regards, Stefan
sphilipp
Hi Aik Eu,
Thank you, your patch worked fine for me, using version 21.1 Standard!
Is there a patch for Lite-version, too?
best regards,
Stefan
aikeu
Hi sphilipp,
I dont think there is a patch for the lite-version.
Aik Eu
sphilipp
Hi All,
Good news for all who encounter the same problem:
I just tested, the same patch works well on the Quartus 21.1 Lite version, too!
Greetings,
Stefan
aikeu
Hi sphilipp,
I wasn't aware that the same patch works as well for lite version.
Good to know that from you, thanks for the info!
I will close this thread for now.
Aik Eu
