16911 Discussions
Quartus 21.1 and Blaster 1
Bop
Hello All,
At the Moment I`m working with "Quartus 21.1 and Blaster 1", when starting download of the *.pof file, with selected Terasic Blaster 1 USB after 4% an error appears.
With the same cabeling and hardware, Quartus 18.0 works for me?
LOG:
Info (209060): Started Programmer operation at Mon Jan 29 08:48:54 2024
Info (209017): Device 1 contains JTAG ID code 0x031810DD
Info (209016): Configuring device index 1
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Jan 29 08:48:55 2024
Info (209024): Programming device 1
Error (209012): Operation failed <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<This
Info (209061): Ended Programmer operation at Mon Jan 29 08:49:18 2024
Any ideas?
Bop
NurAiman_M_Intel
-Have you also try with Quartus v23.1? Does it work?
-What type of Quartus did you used? Standard?
-What is the device used?
-Can you try to compile a simple design and download a pof file using Quartus 21.0? Does it work?
Aiman
Bop
Hi Aiman,
Thanks for responding that fast.
I ll try the 23.1.
I use Quartus (Quartus Prime 21.1) Lite Edition.
The final device is a Motor Controller.
U will here from me.
Regards, Patrick
Bop
Hi  Aiman,
unfortunately 23.1 Lite has the same issue with the Blaster 1. Blaster 2 is ordered for further Tests.
--> Info (209060): Started Programmer operation at Wed Jan 31 14:29:36 2024
Info (209060): Started Programmer operation at Wed Jan 31 14:29:37 2024
Info (209061): Ended Programmer operation at Wed Jan 31 14:29:38 2024
Info (209061): Ended Programmer operation at Wed Jan 31 14:30:01 2024
Regards, Patrick
FvM
Honored Contributor I
I would compare programmer options of both Quartus installations. Under circumstances it is necessary to disable the on-chip configuration controller during programming.
Which is the involved device, is it MAX10?
Bop
Hi, thanks I'll test that.
Yes, it's about 10M02SCE144.
Regards, Patrick
Bop
Hi Aiman,
Quartus 18.0 and Quartus 23.1 have the same settings.
The "Enable real-chip configuration controller" was allready disabled.
Do you have further suggestions?
Regards Patrick
Bop
cancled
NurAiman_M_Intel
Hi Patrick,
While looking for the root cause of your problem, I found below KDB that highlight the same error:
https://www.intel.com/content/www/us/en/support/programmable/articles/000092639.html
We suggest you to use Quartus 19.1 and below for now. Please refer to KDB above.
Aiman
Bop
Hi Aiman,
Thanks for that. This solution works for me with the Blaster 1 and Blaster 2.
Greetings Patrick
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
