16587 Discussions
Quartus 21.1 crashes every ~5 minutes while working with Signal Tap
Val3
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FFDA5AA6840
Module: quartus.exe
Stack Trace:
   0x20683f: QQuickYAnimatorJob::`vftable' + 0x1b3f (Qt5Quick)
   0x20c6ad: QTranslator::translate + 0x1dd (Qt5Core)
   0x217745: QVariant::QVariant + 0xb5 (Qt5Core)
   0x1fc9a6: QMetaCallEvent::allocArgs + 0x116 (Qt5Core)
   0x205d45: QObject::setProperty + 0x245 (Qt5Core)
    0x75673: SEDQ_FRAME_WND::get_plugin_menu + 0xf3 (sld_sedq)
     0xc52e: SEDQ_FRAME_WND::SEDQ_FRAME_WND + 0x5be (sld_sedq)
   0x102e8a: sld_sedq_create_frame_wnd + 0x8a (sld_sedq)
    0x1c729: QUI_FRAME_MGR::create_frame_wnd + 0x1b9 (SYS_QUI)
    0x1c2cd: QUI_FRAME_MGR::create_frame_wnd + 0x28d (SYS_QUI)
    0x1f620: QUI_FRAME_MGR::open_file + 0x430 (SYS_QUI)
    0x639f6: QUI_TOOLS_MENU::sedq_action + 0x1b6 (SYS_QUI)
   0x1fa79f: QMimeData::urls + 0x13af (Qt5Core)
     0x7116: QAction::activate + 0x136 (Qt5Widgets)
   0x161ee7: QMenu::actionGeometry + 0x457 (Qt5Widgets)
   0x161d55: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
   0x167348: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
    0x3a0a5: QWidget::event + 0x145 (Qt5Widgets)
   0x1635bb: QMenu::event + 0x17b (Qt5Widgets)
    0x179ec: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
    0x156f0: QApplication::notify + 0x7d0 (Qt5Widgets)
   0x1da558: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
    0x18d51: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
    0x62022: QSizePolicy::QSizePolicy + 0x2792 (Qt5Widgets)
    0x60276: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
    0x1598e: QApplication::notify + 0xa6e (Qt5Widgets)
    0x5b733: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
    0x46e0a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
   0x2273bd: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
    0x59b48: qt_plugin_query_metadata + 0x1db8 (qwindows)
   0x1d63b0: QEventLoop::exec + 0x1a0 (Qt5Core)
   0x1d924a: QCoreApplication::exec + 0x14a (Qt5Core)
     0x10bb: qgq_main + 0x8b (quartus)
    0x13638: msg_main_thread + 0x18 (CCL_MSG)
    0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x18520: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12df1: msg_exe_main + 0xa1 (CCL_MSG)
     0x20c6: WinMain + 0x156 (quartus)
     0x16d2: __scrt_common_main_seh + 0x116 (quartus)
    0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
    0x52650: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 842
Edition: Standard Edition
Quartus unexpectedly crushes while working with Signal Tap. It's happened couple times in last half of an hour.
SyafieqS
Hi Valeriy,
Is it possible for you to attach the design or small design that replicate the issue?
I will reproduce and work on it.
Val3
It's not reproducible  today, sorry.
SyafieqS
So, the issue is intermittent ?
Can you attach the qar or zip, let me replicate at my end if that's possible
Val3
Thank you for your attention.
I suggest to close this case because it's no longer reproducible.
Val
AEsqu
I noticed that signal tap crashes when the .stp file is moved to another folder,
looks like some paths are then not valid and it crashes.
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
