Hi Quartus Experts, I'm new to Quartus and need some of your suggestions!
My Quartus is running in Fit stage for more than 40+hrs and not completing.
I see only below reports in my run area.
FPGA.drc.partitioned.rpt FPGA.sdc_constraints.rpt FPGA.syn.rpt
FPGA.flow.rpt FPGA.syn.ae.rpt FPGA.syn.summary
I looked into DRC.part*.rpt and i see luts driving 200000+ fanout signals, i enabled GLOBAL_SIGNAL ON for those,
I enabled parallel processing
I'm out of Ideas, what else can be checked in these reports.
Please share some check points, ill try to look into it.
-Thank you
Balaraj M
Hi there, do you have a version which has completed the process?
Maybe you used too many core logic resources in your project.
It got completed with 23.4.0.79-Pro but it took more than 5 days!
I think your project may spend lots of time to conduct optimization. Please check the hierarchy under the project navigate to see if there is any module optimized away like the following results:
The optimization results is as the following:
Thanks let me check, my run is stuck at this point for maximum time.
Hi there, is there any progress on this issue.
