16213 Discussions
Quartus || 32 bit crashes on compile
tal
I am working with quartus for several months.
Today, all of a sudden, after trying to compile my project I got an error message:
Internal Error: Sub-system: THR, File: /quartus/ccl/thr/thr_process.c, Line: 445
Failed to create process!
Stack Trace:
0x1dbe: _thr_internal_error + 0x1e (ccl_thr)
0x15e4: _thr_process_create_and_save_job + 0x404 (ccl_thr)
0x3c5a: IPC_COMMAND::run + 0x3ca (ccl_ipc)
0x5372: flow_call_cmd_thread + 0x122 (sys_flow)
0x1be8: _thr_final_wrapper + 0x8 (ccl_thr)
0x5375: msg_thread_wrapper + 0x85 (CCL_MSG)
0x37e7: mem_thread_wrapper + 0x47 (ccl_mem)
0x213e: _thr_thread_begin@4 + 0x4e (ccl_thr)
0x16358: BaseThreadInitThunk + 0x18 (KERNEL32)
0x67c23: RtlGetAppContainerNamedObjectPath + 0xe3 (ntdll)
0x67bf3: RtlGetAppContainerNamedObjectPath + 0xb3 (ntdll)
End-trace
Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Web Edition
then after pressing ok Quartus crashes.
any help would be great! thanks
RichardTanSY_Intel
Could you help to share your design and the steps to reproduce the error?
May I know which device and OS you are using?
