17120 Discussions
Quartus CLI cpf Error 213035
HB4
Quartus 18.0
When trying to use the CLI to convert a sof file to a jic file, I receive an error stating that the "Error (213035): Configuration device MT25QL256 is illegal".
quartus_cpf -c -d MT25QL256 -s 5CEBA4 Test.sof Test.jic
I changed the device to EPCQ128A and it creates the jic file successfully.
quartus_cpf -c -d EPCQ128A -s 5CEBA4 Test.sof Test.jic
I modified the qsf:
set_global_assignment -name USE_CONFIGURATION_DEVICE OFF
And received the same message.
HB4
The answer is in Article ID: 000076544. Essentially, in Quartus versions prior to 18.1 you need to create a quartus.ini file with the contents pgm_allow_mt25q=on. The other important piece of information is the quartus.ini file should reside in the bin64 folder for CLI to include the MT25Q configuration devices.
Once these pieces are in place, you can successfully create a programming file through the command line interface.
Howard
NurAiman_M_Intel
Have you try to generate the .jic file using Quartus GUI? Is it working?
Also, can you try to use the latest Quartus version?
Aiman
HB4
Yes, it generates the jic file from within Quartus GUI environment.
Howard
HB4
Additional details that might be helpful.
If you launch Quartus and then select "Convert Programming Files..." without opening a project, the list of configuration devices is a smaller collection and does not show the MT25QL256.
Opening a project somehow loads additional configuration devices. Does this sound reasonable? How would I do this through CLI?
Howard
HB4
Howard
NurAiman_M_Intel
Thank for sharing with us.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
