Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Quartus Compile Design text immediately reverts to yellow
I am experiencing a strange problem in Quartus Prime. It has to deal with the "Compile Design" text automatically reverting back to yellow immediately after the "Compile Design" sequence has completed. This problem seems to occur whenever I have "regenerated" a QSYS block, but have not closed and reopened Quartus.
Here is an example of it not happening:
Step 1) Open Quartus Prime
Step 2) Open QSYS
Step 3) Regenerate QSYS
Step 4) Close QSYS
Step 5) Close Quartus Prime
Step 6) Reopen Quartus Prime
Step 7) "Compile Design" --> Text transitions from yellow to green as each step completes. When "Compile Design" is complete, the text stays green.
Here is an example of it happening:
Step 2) Open QSYS
Step 4) Close QSYS
Step 4) "Compile Design" -> Text transitions from yellow to green as each step completes. When "Compile Design" is complete, all text reverts back to yellow.
Any ideas why this is happening and how to get it to stop? We are planning on having a TCL script regenerate QSYS every time, but would also like to see green in the end.
Which version of Quartus? Are you using regular Qsys or Qsys Pro?
For Quartus:
I was seeing it with: Quartus Prime Version 16.1.2 build 203 01/18/2017 SJ Lite Edition
I noticed the same problem on earlier 16.X versions.
I also am still seeing it with Quartus version: 17.0.0 Build 595 04/25/2017 SJ Lite Edition
For QSYS: I am not using Qsys Pro.
QSYS Version: 17.0 Build 595
