16690 Discussions
Quartus Fitter Crashing
mikeyl
Hi, I'm looking to get some help to get my Quartus to work for my digital logic/comp org class. Its been giving me quite a headache. Currently I have the M1 Pro Macbook and I need to run Quartus using a Parallel Boot/VM. I'm able to install Quaratus and compile it however I run into an error while fitting. Is there anything I can do to fix this error. Thank you!
Problem Details
Error:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270
Stack Trace:
    0x48b8c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID::operator unsigned __int64 + 0x2bb4c (DDB_DYGR)
    0x1e780: std::_Hash<std::_Umap_traits<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,std::_Uhash_compare<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID> >,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> >,0> >::_Hashval + 0x10 (DDB_DYGR)
    0x1fc3e: std::unordered_map<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> > >::operator[] + 0x1e (DDB_DYGR)
    0x1db2b: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xff (DDB_DYGR)
    0x189d6: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x66 (DDB_DYGR)
    0x3433b: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x83 (DDB_DYGR)
    0x15360: DYGR_DIE_INFO_BODY::load_data + 0x2a4 (DDB_DYGR)
    0x1d1f7: MPP_ROOT::start + 0x587 (COMP_MPP)
     0x5e5a: qfit_execute_mpp + 0x42 (comp_qfit_legacy_flow)
     0x555b: QFIT_FRAMEWORK::execute + 0x22f (comp_qfit_legacy_flow)
     0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
    0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
    0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
    0x17a65: TclEvalEx + 0xa65 (tcl86)
    0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
    0xa5646: Tcl_EvalFile + 0x36 (tcl86)
    0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
    0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
    0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
    0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
    0x1658d: qexe_run + 0x39d (comp_qexe)
    0x17371: qexe_standard_main + 0xc1 (comp_qexe)
     0x2262: qfit2_main + 0x82 (quartus_fit)
    0x13258: msg_main_thread + 0x18 (CCL_MSG)
    0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
     0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
    0xeae0b: uaw_wcsrchr + 0xe534b (KERNEL32)
    0x84a5f: uaw_wcsrchr + 0x7ef9f (KERNEL32)
   0x1bac4f: ZwWaitLowEventPair + 0x1ac5cf (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.1
Build: 720
Edition: Lite Edition
Space192
I've the exact same error as you guys on M1 pro with quartus on parallels
if anyone find a solution, that would be great
pingu00
So,,,
Who can solve this problem...
iI have same situation.
help
Tom_Gambill
Same exact problem on MacBook Pro M1 in Parallels. It would be great to be able to use this machine for work... there are SO many posts about these issues online with Windows on ARM.
joxheaf21
Any progress on this issue, facing the same.
Jjseg
Same exact problem on a MacBook Pro M1 Max running Parallels 18:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3776
It is always the same exact problem with all designs
Is this issue finally solved?
SkyWT
Same issue on MacBook Air M1 running Parallels 17, Windows11 arm
"Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3776"
It would be great if anyone could provide a solution...
Ryan_S_Intel
This is not a response to the specific IE, but the ways you are seeing them move around.
Note that Quartus is deterministic, e.g. if you start with the same project on the same machine(and let's delete the /db), it will do the exact same steps and give the same results.  (If you change anything though, even as little as the name of a signal in your design, or maybe add a comment, then all bets are off).
So internal errors should not jump around.  When I've seen them, the user can repeat it and get the same one time-after-time.  One thing I have seen when they jump around is corrupted memory on a machine.  I hate suggesting that but throwing it out there.
One other thing I've heard might have an effect is the Number of Processors used.  Maybe try setting this to 1 (I think it defaults to max available) and see if it becomes consistent.
salwa
hi, anyone knows the solution?
SkyWT
I use Quartus 9.0 Free instead, which works in my VM.
dvirc
looks like its been solved in version 23
aseel13
i have the same exact problem could you help me please
dvirc
Whats the error?
Which version of Quartus are you using?
Which OS?
If you're using Macbook with Apple silicon - I was able to overcome the issues using Parallels 19 or above with Win11 and Quartus 23.
Theres still an issue with MegaWizards on QP23 so for that I use QP22.
For ModelSim im using QP16.1.
Fortunately all the issues Ive seen can be solved by using multiple versions of QP over Win11 over Parallels 19 or above.
aseel13
i attached the error. im using quartus prime lite 17 and i have macbook air M1 , im using parallels 19 and win11 , im not sure i understood what megawizards is . Screenshot 2024-06-14 at 13.31.08.png
dvirc
My guess is that its related to the fact that your working directory is located on your Mac which windows considers as remote / network address.
I suggest you try copying your project to your local virtual c:\ under any directory that is not "remote" for windows. For example: c:\Projects\your_project.
If that doesnt work I suggest you try openning your project using QP23.1 while still keeping QP17.1 for future compatibility issues.
I can share that im still zigzagging between QP17.1/22.1/23.1 lite because of compatibility issues.
