- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi, I'm looking to get some help to get my Quartus to work for my digital logic/comp org class. Its been giving me quite a headache. Currently I have the M1 Pro Macbook and I need to run Quartus using a Parallel Boot/VM. I'm able to install Quaratus and compile it however I run into an error while fitting. Is there anything I can do to fix this error. Thank you!
Problem Details
Error:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270
Stack Trace:
0x48b8c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID::operator unsigned __int64 + 0x2bb4c (DDB_DYGR)
0x1e780: std::_Hash<std::_Umap_traits<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,std::_Uhash_compare<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID> >,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> >,0> >::_Hashval + 0x10 (DDB_DYGR)
0x1fc3e: std::unordered_map<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> > >::operator[] + 0x1e (DDB_DYGR)
0x1db2b: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xff (DDB_DYGR)
0x189d6: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x66 (DDB_DYGR)
0x3433b: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x83 (DDB_DYGR)
0x15360: DYGR_DIE_INFO_BODY::load_data + 0x2a4 (DDB_DYGR)
0x1d1f7: MPP_ROOT::start + 0x587 (COMP_MPP)
0x5e5a: qfit_execute_mpp + 0x42 (comp_qfit_legacy_flow)
0x555b: QFIT_FRAMEWORK::execute + 0x22f (comp_qfit_legacy_flow)
0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
0x1658d: qexe_run + 0x39d (comp_qexe)
0x17371: qexe_standard_main + 0xc1 (comp_qexe)
0x2262: qfit2_main + 0x82 (quartus_fit)
0x13258: msg_main_thread + 0x18 (CCL_MSG)
0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
0xeae0b: uaw_wcsrchr + 0xe534b (KERNEL32)
0x84a5f: uaw_wcsrchr + 0x7ef9f (KERNEL32)
0x1bac4f: ZwWaitLowEventPair + 0x1ac5cf (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.1
Build: 720
Edition: Lite Edition
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The first step for Quartus crashing is to always delete the db and incremental_db folders from your project directory, start Quartus again, and recompile from scratch.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yup I've tried this. Still crashes. Quartus doesn't close, just a popup says software crashed unexpectedly
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Can you share your .qar file so I can reproduce your error? To do this, go to Project>Archive Project.
Nurina
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nurina,
Just for some specifications, I'm currently using Windows 11 ARM on Parallel for Mac with M1 Pro. I've tried Quartus Prime Lite 21.0 and Quartus II and they both give the same issue.
Thanks for your help,
Michael L.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I tried compiling this on Quartus Lite 20.1.1 on my machine twice and both times I received different Internal Errors. However, I was able to compile this on Quartus Std 20.1. Are you able to migrate to Standard edition?
Nurina
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nurina,
Oh interesting. I think Standard edition is paid for, so I'm not exactly sure. But I'll try.
Thank you,
Michael L
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi everyone,
Have you find solution ?
Thanks!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Nope not yet. Can't afford Quartus Standard Edition for just a single class.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I see ! We are now two in this case .. may be !! hahah
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It doesn't make sense why it would work on Standard but not on Lite. What is your target device and are you using any special features, like design partitioning or other options, that might not be available in Lite?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I complety agree with you. I try to just open an old project and when the project open, the error appear.
I try Standard and not lite and the device is DE0-Nano-SoC. No special feature is used
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Mine is able to load and compile the first stage Analysis. My error appears on fitter.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I can't seem to reproduce the error. When I compile on Lite edition there are instances where I can compile successfully. But when I don't, I see different types of Internal Errors.
Do you constantly see the Internal Error posted above? Do you see "Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270" every time you try to compile?
I am reporting this matter to engineering and will let you know of any updates.
Nurina
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Could you share your project in a zipped file?
Nurina
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I tried with the newest Quartus lite version and it worked. I think we need to update software.
But there is few adaptation to do. For instance, install WSL for platform designer because, when the compilation procedure is working, there is some issues about that.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sorry for the late replay as I've been busy with school. I've tried installing WSL on my virtual machine. But I've been getting an error with Ubuntu 20.04. Should I try a different version? Just a note, the error also pops up during the fitter stage.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You could try the latest Lite version. Could you share a zipped file of your project?
Nurina
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@mikeyl , did you find a solution? I'm in the exact same position as you. Just bought a M1 mac and am trying to run Quartus Lite on Parallels
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
