17252 Discussions
Quartus II 12.0 Software Linux no tutorials can be opened
I just installed the Quartus II 12.0 software on my
Xubuntu 12.04 Linux system.
The USB Blaster and so on works fine.
But there is a problem with the tutorials in quartus 2 software!
I can't properly link quartus II to firefox or any other browser in order to be used for interactive tutorial and getting started tutorial e.g.?
In option -> internet connectivity I enterd this link to firefox
/usr/bin/firefox
but nothing happens when I try to to start a tutorial afterwards?
What am I doing wrong?
maybe Quartus doesn't have the right to access to /usr/bin.
Launch Quartus as super user and tell us if you still have this problem.
I already launched Quartus with a "sudo" (gksudo) !!!
If I start it without root-rights no changes in preferences, path, etc. will be saved for the next Quartus session!
That's what I forgot to mention... sorry!
problem with internet connectivity/tutorials still exists!
kind regards
Did you install firefox by yourself or firefox is the version installed with Xubuntu?
I installed firefox by using the Xubuntu repository.
I try to avoid installations by myself
I even tried chromium and it didn't work, too!
I just realized that I even cannot start the pdf tutorials from
the help menu.
So this can't be browser related? Or am I wrong?
--- Quote Start ---
--- Quote End ---
Apparently, it does not work well with Chrome.
--- Quote Start ---
the help menu.
--- Quote End ---
The PDF Tutorials from the help menu are opened in the web browser specified in Quartus (Tools/Licence Setup/Internet Connectivity).
What happens if you lauch /usr/bin/firefox? (maybe the symbolic link does not point to the right place, or does not exist)
Verify once again that /usr/bin/firefox is the web browser of Quartus.
--- Quote Start ---
--- Quote End ---
if I try to launch /usr/bin/firefox from shell firefox starts immediately!
So the symbolic link should be set correctly?!
ok I just tried to use some alternative browsers!
Using "konqueror" or "epiphany" doesn't seem to solve the problem.
Maybe it is helpful to mention my quartus install path?
it's
/opt/altera/quartus/
don't know if that's a problem?
maybe the resources that quartus tries to open using the specific browser are placed at a different path? if so what is the correct path and how to change it?
kind regards
I just found out this problem also exists for NIOS2 software!!
firefox cannot be launched as well?
--- Quote Start ---
--- Quote End ---
I think this is the problem.
When I lauch Help/PDF Tutorials/PDF Tutorial for VHDL users, in Quartus, it opens firefox and the address is "file:///c:/altera/11.1/quartus/common/help/tutorial_quartusii_intro_vhdl.pdf". Then, verify if this file is in the same path "[...]/quartus/common/help"
I put a bad path for the web browser and I got an internal error with the shutdown of Quartus.
And I think of another thing: my firefox under Ubuntu can't open a PDF, it returns the file to Acrobat Reader (because I didn't install a pdf plugin for firefox). See if firefox can open a pdf.
If these solutions don't work, put the path of the pdf reader of Xubuntu in the web browser field.
no it doesn't work even when I put my pdf reader (okular) path directly into quartus it does not work at all!
My workaround is :
some direct links to the folders respectively to the html-file to start video tutorial or pdf tutorial comfortably by clicking on desktop shortcuts!
The rest of quartus works fine afaik. So I can start work now or tomorrow because it's too hot here ;)
