17043 Discussions
Quartus II 13.1 Fatal Error: Segment Violation at (nil) in Ubuntu 14.04 32 bits
I'm getting the folowing error:
*** Fatal Error: Segment Violation at (nil)
Module: quartus
Stack Trace:
0x7d674: lh_insert + 0x94 (tls1.6)
End-trace
Quartus II 32-bit Version 13.1.4 Build 182 03/12/2014 SJ Web Edition
I have tried to reinstall every thing from scratch, but did not work. As soon as the program starts the message pop up an the software closes.
I would appreciate any help. Thanks.
I am getting a similar crash using kubuntu-64bit 14.04 virtual machine (vmware 10.0) when I run quartus 32bit, but when I run quartus --64bit I get more trace output:
Module: quartus
Stack Trace:
0x85ce3: lh_insert + 0xb3 (tls1.6)
0x7a48c: OBJ_NAME_add + 0x6c (tls1.6)
0x43f88: SSL_library_init + 0x38 (ssl)
0x1a0056: QObject::event(QEvent*) + 0x376 (QtCore.so.4)
0x1fd924: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0xb4 (QtGui.so.4)
0x2024df: QApplication::notify(QObject*, QEvent*) + 0x12f (QtGui.so.4)
0x18b27c: QCoreApplication::notifyInternal(QObject*, QEvent*) + 0x8c (QtCore.so.4)
0x18e8a8: QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 0x328 (QtCore.so.4)
0x18a062: QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x32 (QtCore.so.4)
0x18a31d: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x14d (QtCore.so.4)
0x18ed4b: QCoreApplication::exec() + 0xbb (QtCore.so.4)
0x7dc1: __gxx_personality_v0 + 0x3b9 (quartus)
0x3bb9a: msg_main_thread(void*) + 0x10 (ccl_msg)
0x75bc: thr_final_wrapper + 0xc (ccl_thr)
0x3c801: msg_thread_wrapper(void* (*)(void*), void*) + 0x5b (ccl_msg)
0x16e45: mem_thread_wrapper(void* (*)(void*), void*) + 0xc5 (quartus)
0xf41d: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x799c: thr_thread_wrapper + 0x15 (ccl_thr)
0x4e41d: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x96 (ccl_msg)
0x7e85: __gxx_personality_v0 + 0x47d (quartus)
0x21ec5: __libc_start_main + 0xf5 (c.so.6)
0x7c99: __gxx_personality_v0 + 0x291 (quartus)
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
I am using RHEL 5.5 I am facing the same error. Can some one please help me to solve this problem ?
*** Fatal Error: Segment Violation at 0x4
Module: quartus
Stack Trace:
0x1741e: atcl_set_package_version(char const*, char const*, bool) + 0x94 (ccl_atcl)
0x1a81c: ATCL_HELP::set_package(char const*, char const*, char const*, char const*, bool) + 0x88 (ccl_atcl)
0x1a8f7: atcl_begin_package_setup(char const*, char const*, char const*, char const*, bool) + 0x46 (ccl_atcl)
0xb4f9d: tdb_advanced_tdb12_unregister_tcl + 0x79 (tsm_tdb)
0xb4fe2: Advanced_tdb12_Unload + 0x14 (tsm_tdb)
0xb3f39: TDB_AUTO_ADVANCED_TDB12_TCL_INIT::~TDB_AUTO_ADVANCED_TDB12_TCL_INIT() + 0x29 (tsm_tdb)
0x2c1b9: __cxa_finalize + 0xa9 (c.so.6)
0xd3a: dlclose + 0x2a (dl.so.2)
0x87bd: thr_drl_native_unload + 0x35 (ccl_thr)
0x8bef: thr_drl_unload_internal + 0x61 (ccl_thr)
0x8ccf: thr_drl_unload_dependents + 0x9b (ccl_thr)
0x8c1b: thr_drl_unload_internal + 0x8d (ccl_thr)
0x9823: thr_drl_unload_all + 0x3f (ccl_thr)
0x997f: thr_drl_fini + 0x8 (ccl_thr)
0x9b04: THR_INITIALIZER::~THR_INITIALIZER() + 0x14 (ccl_thr)
0x2bf09: exit + 0xe9 (c.so.6)
0xd0c4: _IceWrite + 0xf4 (ICE.so.6)
0xd102: IceFlush + 0x32 (ICE.so.6)
0x2a17: SmcSetProperties + 0x287 (SM.so.6)
0x55e9: _SmcProcessMessage + 0xe49 (SM.so.6)
0x12059: IceProcessMessages + 0x3c9 (ICE.so.6)
0x195ec2: QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 0x272 (QtCore.so.4)
0x1e5873: QSocketNotifier::activated(int) + 0x43 (QtCore.so.4)
0x19cb27: QSocketNotifier::event(QEvent*) + 0x147 (QtCore.so.4)
0x1566b4: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0xb4 (QtGui.so.4)
0x15b31e: QApplication::notify(QObject*, QEvent*) + 0x15e (QtGui.so.4)
0x17defb: QCoreApplication::notifyInternal(QObject*, QEvent*) + 0x7b (QtCore.so.4)
0x1afb58: QEventDispatcherUNIX::activateSocketNotifiers() + 0xe8 (QtCore.so.4)
0x1b0816: QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timeval*) + 0x2b6 (QtCore.so.4)
0x1b1326: QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xb6 (QtCore.so.4)
0x181ee1: QCoreApplication::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x41 (QtCore.so.4)
0x1b24fa: QWidgetPrivate::show_helper() + 0x26a (QtGui.so.4)
0x1b276b: QWidget::setVisible(bool) + 0x1cb (QtGui.so.4)
0x42200: QUI_APP::process_cmdline_arguments_pre_main_wnd_create(QUI_CMDLINE*) + 0xa0 (sys_qui)
0xc31c9: QUI_APP::init_instance(int, char const**, QUI_CMDLINE*) + 0x17f (sys_qui)
0x10bc9: QGQ_APP::init_instance(int, char const**, QUI_CMDLINE*) + 0x143 (sys_qgq)
0x63be: __gxx_personality_v0 + 0x35a (quartus)
0x281da: msg_main_thread(void*) + 0x18 (ccl_msg)
0x529e: thr_final_wrapper + 0xe (ccl_thr)
