17054 Discussions
Quartus II 14.0 compatibility issue with 13.0
Hi All,
I have a question regarding compatibility issue.
I have recently installed Quartus II 14.0 in my laptop.
When I tried to use colleague’s project file (.qar) to re-generate binary file (.sof), it didn’t seem to function properly.
After I programmed .sof file, motor didn’t travel smoothly, but rather bumpily.
I found that my colleague was using Quartus II 13.0.
And I installed Quartus II 13.0 and re-compile the same project, then the FPGA image worked fine.
Here is detail information of Quartus version.
Colleague: Quartus II Web Edition 13.0.1 Build 232 SP1
Mine: Quartus II 14.0.0 Build 200 SJ Full Version
I assume that the latest version (14.0) should support old version (13.0), but is there any compatibility issue with it?
I appreciate your help.
Byung Hwa Kim
Is there any Altera IP in the project? If so, was it re-generated prior to running it through Q14?
I'm not convinced this is the issue. However, without quite a bit more to go on we're going to be guessing somewhat...
Cheers,
Alex
There are a few things that could cause this....
1. Is the design fully synchronous? did it meet timing? If it is not fully synchronous, then the move to a new version and recompile is going to affect the timing of the design.
2. Any IP used? was it upgraded for a new version?
