Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Quartus II Internal Error -- Please Help!
I am using Quartus II 64 Bit Version 13.0 for my project on the Arria V GX Starter Board. I am designing a transceiver which would accept 1.25gbps stream of data and see if the data violates the 8b/10b encoding scheme. I have created "Arria V Transceiver Native PHY", "Transceiver PHY Reset Controller" and "Transceiver Reconfiguration Controller" modules and am trying to instantiate them all in the top level entity file called "top". However, during simulation I am running into the error given below. I would really appreciate it if someone could help me out with the problem. I can provide more info as necessary.
--- Quote Start ---
Internal Error: Sub-system: CUT, File: /quartus/db/cut/cut_arriav_hssi_pcs_coreclk_legality.cpp, Line: 536
local_tx_pcs_atom != NULL
Stack Trace:
0x461401: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::report_rmfifo_mode_bad_rx_coreclk_source + 0xf1
0x461bef: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::check_pcs_8g_rx_coreclk + 0x29f
0x461d8b: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::are_coreclk_connections_valid + 0xcb
0x85b56: hssi_fpp_create_module + 0x192c6
0x1c3e6: FSV_U2B_POSTFIT::operator= + 0x8226
0x12ee1: fsv_execute + 0x2a11
0x13c45: fsv_execute + 0x3775
0x104f2: fsv_execute + 0x22
0xb959: fmain_start + 0x7e9
0x2225: Legacy_fitter_Init + 0x11b5
0x1ea8: Legacy_fitter_Init + 0xe38
0x2e68: Legacy_fitter_Init + 0x1df8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xbd5f: qexe_ipc_progress_bar_name + 0xf3f
0x11498: qexe_get_command_line + 0x1068
0x147a5: qexe_run_tcl_option + 0x585
0x1dacd: qcu_run_tcl_option + 0xb8d
0x14dbd: qexe_process_cmdline_arguments + 0x54d
0x14f21: qexe_standard_main + 0xa1
0x4ae8: msg_exe_fini + 0x58
0x522c: msg_exe_fini + 0x79c
0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5e0f: msg_exe_main + 0x8f
0x1652c: BaseThreadInitThunk + 0xc
0x2c520: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.0 Build 156 04/24/2013 SJ Full Version
--- Quote End ---
Highlighted
Re: Quartus II Internal Error -- Please Help!
One of the possible root causes of this IE is that your design contains Receiver Only channel with Rate Match being turned on. Rate Match FIFO is clocked by the clock from the transmitter channel of the same physical location, therefore, if the use of Rate Match FIFO is intended, you will need to create a duplex channel. Otherwise, just disable the Rate Match FIFO.
Let me know if this works.
Highlighted
Hello leeping82,
I was able to fix the issue exactly as you mentioned!
--- Quote Start ---
--- Quote End ---
