Hi, I don't know if this problem has been asked a lot but my friend and I couldn't compile my project because of an internal Quartus II error. Here's the log generated.
*** Fatal Error: Access Violation at 0X00007FF9FE7F4747
Module: quartus_map.exe
Lock in use: 54
Stack Trace:
0x14746: OPT_RAM_AI::OPT_RAM_AI + 0x114b6
0xbc64: OPT_RAM_AI::OPT_RAM_AI + 0x89d4
0xb6f5: OPT_RAM_AI::OPT_RAM_AI + 0x8465
0x45f8b: opt_bdd_small_arm_entry + 0xb9cb
0x49103: opt_bdd_small_arm_entry + 0xeb43
0x527ec: RTL_ROOT::process_sgate_netlist + 0x1dc
0x13e001: sgn_clear_check_ip_functor + 0xb3e01
0x1400e8: sgn_clear_check_ip_functor + 0xb5ee8
0xa41d6: sgn_clear_check_ip_functor + 0x19fd6
0xa6a44: sgn_clear_check_ip_functor + 0x1c844
0xa73ca: sgn_clear_check_ip_functor + 0x1d1ca
0x10dc7: sgn_qic_full + 0x257
0x11fad: qexe_get_command_line + 0x1b7d
0x14e0e: qexe_process_cmdline_arguments + 0x59e
0x14f21: qexe_standard_main + 0xa1
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x11fe3: BaseThreadInitThunk + 0x13
0x6efc0: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
Thanks!
Try deleting db and work folder and check. Can you attach and project? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
the above fatal error is not quartus error. Debug Steps followed: In the above code, the interface between the data_memory and instruction control is having problem. 1.For debug,Comment each block one by one block (port map) to find the logical error. 2.The "instruction control" logic caused problem, so i have changed only the constructor not the logic and to reduce the warning i have changed the logic of "data memory" which is commented in attached. 3.Used quartus 17.0 std, windows which solved the problem. You can try it once in your code before downloading the code attached. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
Looks like the Quartus MAP tools have crashed due to access violations. Can you make sure that there are no other instances of Quartus open and running. Check the processes in Linux or Task Manager in Windows and kill any other quartus tasks that are running. Be careful not to kill the one you are currently running. If this doesn't work, close the tools, restart the system and try.- Mark as New
That solved the problem. Thanks!
