17255 Обсуждение
Quartus II v.11.0
Почетный участник II
3 018Просмотр.
Help, please.
When I try to compile some project using QUARTUS II v.11.0 or v.10.01 (web edition bouth) i get these messages:
Info: You have a valid up-to-date license
Error: Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist
Error: Current module quartus_asm ended unexpectedly
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings
I use Wwindows xp sp3, with hardware which meets QUARTUS requirements (512 Mb of Ram)
There was no errors during installation process, I have tied to download License file and use it, to reinstall program, to install fresh coppy of windows and than QUARTUS... nothing helps.
I know that there is more threads on this subject, but there is no solution, so I ask again. I
Apologize for my English.
0 баллов
20 Ответы
2 212Просмотр.
i've seen this on the forum before, but i'm not sure if it was resolved. have you taken a look?
2 212Просмотр.
I read these (two or three) posts and did not help me. Any other idea ?
2 212Просмотр.
can you start a new project for scratch and target a recent device (CIII or CIV)? just run a small design like a counter and see if it runs all the way through compilation
2 212Просмотр.
I have tried that and still getting same messages:
2 212Просмотр.
that's really strange
you said you're using Web Edition and a license file. can you try the counter test project without any license assigned to Quartus?
2 212Просмотр.
Tried to work without license file, messages are same.
2 212Просмотр.
have you tried to delete all subdirectories (e.g. "db", "incremental_db",..) and start a recompilation (deleting the subdir forces a complete recompile...)
Give it a try..
Carlhermann
2 212Просмотр.
-I have made new project and tried to compile it, and I have got errors, so it is a complete recompilation.
-I am trying to enable "Talk back" function, but I dont know what is FAE (field application engineer) username, or where to get it.
-Btw, now I use version 9.1 and it works without errors, but I would like to find solution for problems with newer versions...
2 212Просмотр.
Well - can you post the Archieved projekt as it's easier to play around and post the answer than doing wild guesses...
Sincerely, Carlhermann
2 212Просмотр.
Where can I find software release notes for quartus ii version 11.0? Now I can find quartus ii version 10.1 sp1 software release notes only. Even in page quartus ii subscription edition.
2 212Просмотр.
I ASK AGAIN:
What is FAE (field application engineer) username, and where to get it (need it for Talk back function)???
I have uploaded some simple project which cannot be compiled by my Quartus.
2 212Просмотр.
Konst: the QII Release Notes are normally delayed from the software release by a couple of weeks
2 212Просмотр.
bosandzeros: if you don't work with an FAE you don't need to fill out that field. if you do you can just ask your FAE
i don't think this is the root cause of your problem
2 212Просмотр.
i am able to compile your design successfully with QII 11.0 64-bit Subscription Edition on Windows 7
2 212Просмотр.
Even I can compile that project on my PC with QUARTUS v9.1, but i would like to find solution for problem with newer versions.
2 212Просмотр.
Any other ideas?
2 212Просмотр.
I compiled it OK with Quartus II Web Edition 11.0:
Total combinational functions 25 / 5,136 ( < 1 % ) Flow Status Successful - Sat Aug 13 23:26:26 2011
Dedicated logic registers 14 / 5,136 ( < 1 % ) Quartus II Version 11.0 Build 157 04/27/2011 SJ Web Edition
Revision Name Led_Blink
Top-level Entity Name Led_Blink
Family Cyclone III
Total logic elements 25 / 5,136 ( < 1 % )
Total registers 14
Total pins 2 / 183 ( 1 % )
Total virtual pins 0
Total memory bits 0 / 423,936 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 46 ( 0 % )
Total PLLs 1 / 2 ( 50 % )
Device EP3C5F256C6
Timing Models Final
2 212Просмотр.
I know that you can compile it, problem is because I can't do it... So what could be problem with my program?
2 212Просмотр.
There can't be anything wrong with your code, if I can compile it. You must have a problem with your Quartus II installation.
2 166Просмотр.
I KNOW THAT PROBLEM IS IN QUARTUS II, but I don't have solution for QUARTUS II problem!!!
Ответить
