17093 Discussions
Quartus Prime 16.1 Lite compilation issue
Hi All,
I met a problem that my software cannot generate an 500ms counter, see my code and picture, can you help me?
https://alteraforum.com/forum/attachment.php?attachmentid=13466&stc=1
/********************Test01*********************** Project Name: Test01; Function: Just test my FPGA board Version: 0.1 Editor: Vincent Li Date: 2017-04-03 clk=50MHz *************************************************/ module test01( clk, nRST, LED ); input clk,nRST; output LED; parameter T500MS = 25'd24_999_999; reg rLED; reg Count; always@(posedge clk or negedge nRST) if(!nRST) Count <= 25'd0; else Count <= Count + 1'b1; always@(posedge clk or negedge nRST) if(!nRST) rLED <= 4'd1; else if(T500MS==25'd24_999_999) rLED <= {rLED,rLED}; assign LED = rLED; endmodule
(Virus scan in progress ...)
Here is the problem:
This is always true - I think you meant count?
Hi Tricky,
thank you for your reply, yes you are correct...I had corrected this morning and it works.
Br
