Qsys VHDL generation fails due to an issue with Nios II. Tracing this back leads to an executable within the Quartus installation of Cygwin that exists under ../quartus/bin64/Cygwin.
Running bin/bash.exe has mixed results with some executions failing. Attempting to run a command within the opened bash shell also has mixed results; either the command isn't found at all or it errors with Win32 error 487 (see below).
$ ls
bash: ls: command not found
$ ls
2 [main] bash 6916 C:\intelFPGA\18.1\quartus\bin64\cygwin\bin\bash.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x640000 - 0x840000, (child has 0x800000 - 0xA00000), Win32 error 487
797 [main] bash 6916 cygwin_exception::open_stackdumpfile: Dumping stack trace to bash.exe.stackdump
1 [main] bash 11516 fork: child -1 - forked process 6916 died unexpectedly, retry 0, exit code 0x100, errno 11
bash: fork: retry: Resource temporarily unavailable
tl;dr: A seemingly ancient error has apparently resurfaced in my Quartus install.
What is the best fix for this issue? And considering this was a fresh install of Quartus Prime, I must admit this is not particularly encouraging.
- Tags:
- qsys
Realised this may be an issue with not having applied Update 1, if this is the case, it might be worth having something a little more obvious that there is a critical update required.
Did you try to remove and reinstall the tool correctly. What is the machine and OS you are using?
Yes I've since installed the correct update and the Cygwin installation itself works -- we encountered some other issues though (posted by itself) which are being addressed.
The machine is a Dell Latitude with Windows 10 1809 installed; this meant that replacing Cygwin with WSL was a viable option.
Ainsley
Great,
Can you explain more about the update you used to solve this issue?
