17159 Discussions
Quartus Prime: Inferring latch(es) for clocked process
EPeet
I have a normal process with async reset and clock like below:
request_pulse   : in std_logic;
signal pulse_in_d     : std_logic;
signal request_int    : std_logic;
signal flop_d       : std_logic;
p_dest_clk : process(dest_clk, dest_resetn)
  variable v_pulse_in_mxd : std_logic;
begin
if dest_resetn = '0' then
   pulse_in_d     <= '0';
request_int    <= '0';
elsif rising_edge(dest_clk) then
    if generic1 then
      pulse_in_d    <= request_pulse;
      v_pulse_in_mxd  := request_pulse and not pulse_in_d;
    else
      v_pulse_in_mxd  := request_pulse;
    end if;
    if generic2 then
      if generic3 then
       request_int <= v_pulse_in_mxd xor request_int;
      else
       request_int <= not flop_d;
      end if;
    else
      request_int <= '0';
    end if;
   end if;
  end process p_dest_clk;
Generic1 and generic3 are set to false, generic2 is true. As the whole process is sequential, I don't understand why I get the following warning:
Warning (10631): VHDL Process Statement warning at gen_resync_data_receive.m.vhd(79): inferring latch(es) for signal or variable "pulse_in_d", which holds its previous value in one or more paths through the process.
EPeet
Interesting.
When I simply replaced the generics (set either to true or false) by input ports (tied either to '1' or '0'), the warnings about the latches are gone.
Seems to me like a tool bug...
Tricky
New Contributor II
As this is a code snippet, and doesnt reflect the real code, we can only guess as to what the problem is.
But in your conditions, Pulse_in_D is only assigned a value during reset, and cannot be assigned any values when reset = '1', hence you've made a latch with reset='0' as the enable.
