Hi there,
As per the Release Notes for the above referred release it looks like ModelSim is no longer available but the Questa. Can someone confirm that for me please?
Many thanks!
With Quartus 21.1, Simulator switched to Questa. You can still simulate most designs with older ModelSim versions.
Hi FvM,
Thanks for jumping in here.
I see, then I guess I should downgrade my suite to say, @ least 20.1 in order to be able to get ModelSim in. Unless the latest suite version would allow me to incorporate ModelSim from 20.1 in.
Kind regards,
Quartus version Lite/STD of 20.1 is the last to support modelsim.
Onward is Questasim, thus I guess it is correct.
You may check it manually in download page
ModelSim and QuestaSim basically work the same. Very little reason to not use QuestaSim. I believe it runs faster and supports larger designs.
Let me know if there is any update at your end
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
