All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
16497 Discussions
Quartus (Quartus Prime 21.1) Lite Edition crashes when starting and creating a new project in window
hunter_works
Hello to all the experts!
I am a person trying to learn FPGA.
I have installed Quartus Lite Edition on windows 11 environment.
When I start the software and try to browse to a folder from Create New Project, it gets stuck for a few seconds and then the software crashes.
How can I solve this problem?
Any help would be appreciated.
SyafieqS
Hello Taisei,
Let me know if there is any other concern or update from your end Im gladly to help.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
SyafieqS
Hello Taisei,
Firstly I doubt that 21.1 Lite have adopted to Win 11 yet. You may check the readme.txt file in the installation path. Secondly, you should not set your path to default Quartus path when creating new project, change it to another path, this should be working.
hunter_works
Hi SyafieqS
Thanks for the reply!
I was remiss in not checking the system requirements...
It is true that windows 11 is not guaranteed to work on 21.1 Lite edition...
Thanks for letting me know!
Much appreciated!
SyafieqS
Hello Taisei,
SyafieqS
 I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
