Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Quartus​ WEB版License授权失败
从官网申请了license授权文件后,在Quartus​ web版中进行加载,但按照说明加载后,做仿真时还是提示license文件授权失败。
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Modelsim-Altera uses the following environment variables to check the licenses (listed in the order of preference)
1. MGLS_LICENSE_FILE
2. LM_LICENSE_FILE.
Highlighted
Hello
Welcome to INTEL forum. Based on my understanding, Quartus web edition is provided free and no license require.
Highlighted
Then why do I prompt the license authorization failure during the simulation?
Highlighted
Hi
Could you provide message screenshot and error message for checking
Highlighted
Highlighted
Highlighted
To further investigate could you provide your PC NICID (Mac Add) And for privacy, you can also reply/attach your file in private message.
