Hi!
Hopefully someone here will know the answer :D I´m wondering about the Quartus II and safety critical systems. I´ve found on your webpage that it´s qualified for DO-254. But what about the ISO 26262, IEC 61508 and ENV 5012x? Is it sufficient to prove that it applies for DO-254 and therefore should apply to the others? Best regards, ErikLink Copied
I suggesting raising a mysupport case direct with altera as it seems to be a rather technical question.
Altera themselves tend not to reply to threads on this forum.- Mark as New
Hi Erik,
have a look at http://www.altera.com/end-markets/industrial/functional-safety/ind-functional-safety.html?gsa_pos=1&wt.oss_r=1&wt.oss=functional safety (Or try "functional safety" in search at ALTERA homepage) There exists a IEC61508 qualification by German "TÜV" for defined versions of QuartusII and related FPGA HTH, Carlhermann
