When we were using quartus for the synthesis process, we encountered a problem that caused the program to crash abnormally. Our 'rtl.v' file, which is set to be the top file of the quartus project, experienced an interruption in the synthesis process, which eventually caused quartus to crash. In order to facilitate the recurrence of the problem, we have attached the project where the crash occurred to the submission, in the hope that this will help you locate and resolve the issue.
- Tags:
- synthesis
I able to duplicate the issue and have submitted a case to the engineering team to investigate. I will keep you updated as soon as there is any progress or findings.
Since this is from an older Quartus software, there may be limited resources to fix this issue, and a workaround will most likely be provided. I hope you understand.
p/s: Please keep in mind that any work involving our engineering team may take some time, ranging from a few days to a few weeks, depending on the complexity of the issue.
Richard Tan
As of now, I have not received any update from the engineering team.
I will continue to follow up with the engineering team and provide you with an update as soon as possible.
Thank you for your patience and understanding.
Richard Tan
Engineering found that the root cause of the error is that Quartus standard incorrectly processes the escaped names of the type
reg [7:0] \cfblk203_reg[0] ;
This is in the file Subsystem_yosys.v
I see that the file is generated bythe yosys tool. yosys may have an option to generate the names differently.
For example, if we change the name to
reg [7:0] clkbuf203_reg_0;
This will be handled properly by Quartus standard.
Richard Tan
Dropping a note to ask if the workaround works for you?
Do you need any further assistance from my side?
Richard Tan
I believe the initial issue has been resolved. Now, I will transition this thread to community support.
If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
