16349 Discussions
Quartus cannot run the VHDL file
anonymous661
I download Intel® Quartus® II Web Edition Design Software Version 13.0sp1 for Windows from https://www.intel.com/content/www/us/en/software-kit/711791/intel-quartus-ii-web-edition-design-software-version-13-0sp1-for-windows.html and I download separate files: Intel Quartus Software and Intel® MAX® II, Intel® MAX® V, Intel® MAX® 3000, Intel® MAX® 7000 Device Support. After I install it, I try to design digital systems from the guideline: https://tinyurl.com/ed542ttv . but it cannot run. Any solution suggested?
sstrell
The screenshot seems to show an error with your simulation tool, not Quartus, and you're not showing the error messages you are getting.  Can you show that?
anonymous661
Hello, it just continues to show like in the screenshot and stops there, no result shows. I try to download the package again and install it but still cannot resolve
SyafieqS
Lim,
From the screenshot I see you are trying to do simulation with university program wvf. From the document you followed, which par/step produce such result?
By right, there should be a window simulation result pop up after you click functional simulation.
anonymous661
Hi, the screenshot is the window simulation pop up after I click functional simulation. This is the problem, I wait for a long time, but it execute until there and stops but I don't know what is the problem
SyafieqS
Hi Lim,
Let me reproduce the issue and get back to you with update.
SyafieqS
Lim,
It works properly at my end and I cant reproduce the issue.
Since you mentioned it stuck as snapshot attached, may I know if your machine meet all the requirement for system and software supported device used?
You can refer to link below for Minimum Hardware Requirements
https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/minimum-hardware-requirements.html
anonymous661
SyafieqS
Lim,
Are you able to work on this? or still need help?
Let me know any update on this.
SyafieqS
Lim,
Glad you are able to resolve the issue.
Let me know if there is any concern or update.
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
