17263 Discussions
Quartus co-simulation modelSim FIR problem
pp
Hello seniors
The software I use is Quartus 16.0 standard edition, and ModelSim uses third-party software, version 10.6D
I used Quartus to combine the simulation with ModelSim. The following errors occurred when ModelSim was compiling FIR library, which could not be solved. I request your help
BrusC_Intel
Hello, PP.
Thank you for posting on the Intel Community Support Forums.
There is a dedicated community section for this particular product, the Intel® Quartus® Prime Software, so I will move your thread there so it can be answered as soon as possible.
Bruce C.
pp
SyafieqS
Hi PP,
Can you repost the snapshot with clear error message if possible? The attachment is almost unreadable.
pp
This error says "AlterA_MF" not found,it means the fir ip some files not found the library "AlterA_MF"
SyafieqS
  1. Make sure the IP files are in the project
  2. Remove and add again the ip file to see if able to read
  3. Regenerate the IPs.
