my problem is that Quartus Prime Pro crashes every time when I reach the Fitter stage. I tried everything I could find on the internet and your forum but I cannot fix this problem, please help, thank you very much
Problem Details
Error:
Internal Error: Sub-system: DSPF, File: /quartus/h/shm_mdb_sys.h, Line: 468
Could not load database: d:/intelfpga_pro/23.2/devices/20nm/nightfury1//ddb_nightfury1_dspf_routing_models_100c.mdb (Das System kann den angegebenen Pfad nicht finden.)
Stack Trace:
Quartus 0x103f8: `shm_mdb_open_database<DSPF_WIRE_INFO>'::`1'::catch$8 + 0x64 (ddb_dspf)
Quartus 0x107f: (VCRUNTIME140_1)
Quartus 0x26b4: __NLG_Return2 + 0x1564 (VCRUNTIME140_1)
Quartus 0xa1715: RtlCaptureContext2 + 0x4a5 (ntdll)
Quartus 0x8703: shm_mdb_open_database<DSPF_WIRE_INFO> + 0xd7 (ddb_dspf)
Quartus 0x946f: DSPF_WIRE_INFO::open_database + 0x57 (ddb_dspf)
Quartus 0x6126: DSPF_DB_CACHE::get_db + 0xf2 (ddb_dspf)
Quartus 0x6b47: DSPF_WRAPPER::DSPF_WRAPPER + 0x15b (ddb_dspf)
Quartus 0x73f3c: PTI_RE_CORNER_ANNOTATOR::PTI_RE_CORNER_ANNOTATOR + 0xb38 (tsm_pti)
Quartus 0x725d1: PTI_RE_CORNER_ANNOTATOR::create + 0x7d (tsm_pti)
Quartus 0x723fe: PTI_RE_TREE_ANNOTATOR::PTI_RE_TREE_ANNOTATOR + 0x16e (tsm_pti)
Quartus 0x2b59a: PTI_ROUTING_ANNOTATOR::PTI_ROUTING_ANNOTATOR + 0x1a6 (tsm_pti)
Quartus 0x4b1e1: PTI_DELAY_ANNOTATOR::build_multicorner + 0x405 (tsm_pti)
Quartus 0xdab16: FITCC_TDC_UTILITY::initialize_dat + 0x1296 (fitter_fitcc)
Quartus 0xdbdb2: FITCC_TDC_UTILITY::setup_tdc_utility + 0x1d2 (fitter_fitcc)
Quartus 0xd6d1e: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0xde (fitter_fitcc)
Quartus 0x805b4: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x464 (fitter_fitcc)
Quartus 0x80e23: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x143 (fitter_fitcc)
Quartus 0x80f45: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x95 (fitter_fitcc)
Quartus 0x8fd6d: FSAC_FF_REGISTER_PACKER_OP::perform_timing_analysis + 0x8d (FITTER_FSAC)
Quartus 0x13f185: FDRGN_REGISTER_PACKER::do_packing + 0x215 (fitter_fdrgn)
Quartus 0x74faf: fdrgn_post_plan_ops + 0x64f (fitter_fdrgn)
Quartus 0x26412: fit2_fit_plan + 0x622 (comp_fit2)
Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86)
Quartus 0x17c4d: TclEvalEx + 0x9ed (tcl86)
Quartus 0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86)
Quartus 0x22460: qexe_evaluate_tcl_script + 0x640 (comp_qexe)
Quartus 0x21062: qexe_do_tcl + 0x8c2 (comp_qexe)
Quartus 0x2a1d1: qexe_run_tcl_option + 0x701 (comp_qexe)
Quartus 0x2d2d6: QCU::DETAIL::intialise_qhd_and_run_qexe + 0x116 (comp_qcu)
Quartus 0x3dfcb: qcu_run_tcl_option + 0x76b (comp_qcu)
Quartus 0x2994e: qexe_run + 0x61e (comp_qexe)
Quartus 0x2ac84: qexe_standard_main + 0x264 (comp_qexe)
Quartus 0xbc22: qfit2_main + 0x82 (quartus_fit)
Quartus 0x277b8: msg_main_thread + 0x18 (ccl_msg)
Quartus 0x28772: msg_thread_wrapper + 0x82 (ccl_msg)
Quartus 0x2ac13: mem_thread_wrapper + 0x73 (ccl_mem)
Quartus 0x25415: msg_exe_main + 0x175 (ccl_msg)
Quartus 0xcdaf: __scrt_common_main_seh + 0x10b (quartus_fit)
Quartus 0x17613: BaseThreadInitThunk + 0x13 (KERNEL32)
Quartus 0x526b0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0.19045
Quartus Prime Information
Address bits: 64
Version: 23.2.0
Build: 94
Edition: Pro Edition
Hi, I'm sorry, please find a complete project attached. I have installed Quartus 21.4 now and everything works fine, I can finish my project and do not need any further support. Nevertheless, I hope you can find the bug in the newest Quartus version, as we would like to use it for future projects.
Hi Ozkan,
This seem to me like a bug. Can you attach the design in qar?
Let me take a look.
Let me know if that is possible
Hi, thank you very much for the quick reply! I have attached two sample .qpf files of very simple projects (basically kind of "Hello World" projects). Quartus crashes in the first Fitter stage after the line "Promoted 1 clock (1 global)".
Many thanks for your help!
I just wanted to add that any other project I tried from my colleagues and the internet also crashed. I even uninstalled Quartus Prime Pro and reinstalled it, still the problem persists. And also the timing analysis tool crashes, I tried opening it after the Analysis and Synthesis stages, before the fitter.
Hi Ozkan,
Thanks for the design. Let me reproduce and get back to you with update.
A quick update again: I also tried it on a different PC with a completely different CPU and GPU and Win11 this time, but it also crashes there. I have no idea what is going on.
Now I have tried it with Quartus Prime Pro Version 19.1 and I'm having no issues. Must really be a buy in the newest or newer Versions of Quartus (I haven't tried any other Versions yet).
Thanks for the feedback. I am checking this with developer.
Does this issue total roadblock your design?
Is 19.1 feasible for workaround temporary?
The design attached seem there is no design, just a qpf file.
Can you attached in qar? If it is confidential, you may reply to my email to attach it.
Hi CodeDe.
Massive thanks the for the design and feedback, I will forward this to developer for further debugging.
Since there is workaround, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
