Hello ALL,
Initially, I have successfully installed the Quartus 17.1.2 (304) on a server with Centos 6.10.
As I was told that Quartus is supported from Centos 7 and up, I decided to move to Centos 7.6
After installing the Centos7.6 I tried to install the Quartus (17.1.1, 18.0 and 18.1) but without success.
The installation is stack at the end, and there is no way to run Quartus.
As part of the Quartus installation on the Cento6.10, I had the same experience (stack at the end) but after killing the installation process, I could run Quartus normally.
This is not the case now.
After killing the process after few hours of waiting for the installation to end, I cannot run Quartus.
The server parameters are as follow:
12 X Cores CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
64G RAM
300G free on hard drive
No antivirus is installed
>free
total used free shared buff/cache available
Mem: 65731936 1586940 28863512 18044 35281484 63456944
Swap: 32964604 0 32964604
One more thing, I tried to install Quartus on a VM (Xeon CPU) with Centos7.6 on it that I got from our IT group and it also did not complete the installation. (I did it to verify that our I7 server is not to blame)
Kindly advise,
Hi YRose3,
May I know the source of the following info?
'As I was told that Quartus is supported from Centos 7 and up'
Kindly refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.h... for official supporting OS.
Besides this, you may try
1) Disable anti virus and reinstall the software ( including all the devices)
2) If #1 does not work, try workaround suggested in https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base...
Please let me know if you have any questions.
Thanks for your help KYeoh.
Hi YRose3,
Could you try to install the updates individually like what you did when you install the software?
Can you install the following updates individually?
aocl-pro-rte-17.1.1.273-linux.run
AOCLProSetup-17.1.1.273-linux.run
DSPBuilderProSetup-17.1.1.273-linux.run
ModelSimProSetup-17.1.1.273-linux.run
QuartusProProgrammerSetup-17.1.1.273-linux.run
etc
OK.
So, that was a good suggestion.
I think it is 90% OK now.
thanks
Hello KYeoh ,
OK.
I reinstalled the 17.1.1 upgrade with success.
it looks 100% OK now (DSP installed + "about" is 17.1.1)
Thanks for your help 👍
Yair
Hi Yair,
It is glad to hear that.
