I have a client who purchased a license for Quartus 17.1, but is not recognizing it.
Activate the license in the Self-Service portal, then in Quartus, in the License Setup section, when indicating the path, it shows the following error in Software Guard ID: Not Found
Also, how do you generate the license file with the Quartus and Nios license? they tried a couple of different things with no luck.
Regards.
Hello
Welcome to Intel forum. Could you help to reconfirm the license setup again. You can refer to link below for more detailed instructions for Setting up a license.
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
Let me know if this information is helpful.
We have not heard from you and I hope that my last note clears up this matter. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
