16352 Discussions
Quartus v19.1.0 Project clean fails
KHill
Hello folks;
Quartus 19.1 was just installed on a Win10 PC. I made a simple example modelling an XOR gate with a DE0-CV board.  I noticed that after a full build, the project>>clean command works fine,
But after building and then opening/closing the programmer, the project>>clean command fails.
Any ideas what's going on or how to fix?
Nurina
Did you do anything on the Programmer tool, or did you just open and close it after compilation?
Can you attach your qar file?
Nurina
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
