16596 Discussions
QuartusII Critical Warning:Ignored Power-Up Level option
Hi all,
compiling my prject, I received this warning message:
critical warning: ignored power-up level option on the following registers
critical warning: register \freqcontrolloopprocess:nperiodcount[3] will power up to low
critical warning: register \freqcontrolloopprocess:nperiodcount[2] will power up to low
critical warning: register \freqcontrolloopprocess:nperiodcount[1] will power up to low
critical warning: register \freqcontrolloopprocess:nperiodcount[0] will power up to low
critical warning: register ndivisorh[3] will power up to high
critical warning: register ndivisorl[3] will power up to high
Where am I going wrong?
Have you tried to power up some registers high, whilst resetting them to '0' with an async reset?
Yes, in fact I set:
ndivisorh : integer range 0 to max_cnt-1:=8;
because reset value is:
if reset_i='1' then
ndivisorh<=8;
the solution is to set the regs initially to the reset value they assume when reset='1' in the code.
The warnings you posted dont refer to nDivisorH. They refer to nPeriodCount and nDivisorL
even to nDivisorH
--- quote start ---
Critical Warning: Register nDivisorH[3] will power up to High[/B]
--- Quote End ---
[/B]
Then I assume you've set an assignment that tells them all to power up low.
