Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
QuartusII ver18.1で下記設定を使用できますか。 set_global_assignment -name SEU_FIT_REPORT ON
検討製品:MAX10
*.qsfに記述しましたがコンパイル後のレポートファイルに反映されませんでした。
Highlighted
Re: QuartusII ver18.1で下記設定を使用できますか。 set_global_assignment -name SEU_FIT_REPORT ON
Yes, you can use these setting with Quartus standard edition, please refer the below application note & video,
https://www.intel.com/content/www/jp/ja/programmable/documentation/drj1530911544883.html#esc14582377...
https://www.youtube.com/watch?v=eqcmuwGpGAI
please let me know if you have any different concern.
Vicky
Highlighted
回答ありがとうございます。​
「Obtain and install the SEU license.」と書かれてます。ライセンスの取得方法とインストール方法を教えてください。
Highlighted
Highlighted
​Hi Vicky,
regarding the SEU report topic, I have the following questions:
  • Can the SEU report also be made available for the Quartus Prime LITE edition?
  • Is there a separate license type required to create the SEU report?
  flho
Hi flho,
Can the SEU report also be made available for the Quartus Prime LITE edition? ---- No, either you can use Pro or Standard edition.
Is there a separate license type required to create the SEU report?----- Yes, refer the links below for more details.
For all license refer Intel SSLC.
Vicky
