検討製品:MAX10
*.qsfに記述しましたがコンパイル後のレポートファイルに反映されませんでした。
Yes, you can use these setting with Quartus standard edition, please refer the below application note & video,
https://www.youtube.com/watch?v=eqcmuwGpGAI
please let me know if you have any different concern.
Vicky
回答ありがとうございます。
「Obtain and install the SEU license.」と書かれてます。ライセンスの取得方法とインストール方法を教えてください。
please refer the links below,
https://fpgasupport.intel.com/Licensing/license/index.html
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-software/licensing.html
Vicky
Hi Vicky,
regarding the SEU report topic, I have the following questions:
- Can the SEU report also be made available for the Quartus Prime LITE edition?
- Is there a separate license type required to create the SEU report?
flho
Hi flho,
Can the SEU report also be made available for the Quartus Prime LITE edition? ---- No, either you can use Pro or Standard edition.
Is there a separate license type required to create the SEU report?----- Yes, refer the links below for more details.
For all license refer Intel SSLC.
Vicky
