16595 Discussions
Questa/Modelsim, long SV variable in object
KVino1
I have the same problem on Intel free Modelsim and both in Commercial Questasim CADs.
Here's my SystemVerilog signals, I want to check in simulator
logic [8191-1:0] ram_buffer0 ; logic [8192-1:0] ram_buffer1 ; logic [4000-1:0][2-1:0] ram_buffer2 ;
The problem is that there's no ram_buffer1 variable in objects list pallete in saved WLF file. I can't add to waveform both manually and through command
# (vish-4014) No objects found matching 'vsim:/row_buffering_tb/UUT/ram_buffer1'.
This problem happens when variable size more then 8191 elements.
My shell scripts is also quite simple
vdel -lib work -all   vlib work     vmap work $PWD/work rtl=../rtl tb=../tb   verlist=( $rtl/row_buffering.sv $tb/row_buffering_tb.sv )   for src in "${verlist[@]}" do vlog -sv $src done   vsim -t ps -novopt work.row_buffering_tb -do "log -r /*; run 2 us; exit;"
The problem is with saving signal into WLF - I can do something like
logic [10000-1:0][5:0] test_ram_buffer_long ; logic [5:0] test_ram_buffer_last ; assign test_ram_buffer_long[10] = 42; assign test_ram_buffer_last = test_ram_buffer_long[10];
There will be now in test_ram_buffer_long in object list, but assignment of test_ram_buffer_last will works fine.
The problem doesn't depend on packed/unpacked array declaration type
Vicky1
Can you share the project file or row_buffering_tb.sv file, if possible?
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Abe
Valued Contributor II
I just tried the same with a simple RAM model and I'm able to view all the mem_buffs in the object browser. Take a look at the screenshot
Same with mem_buff3 size 4096x20
