Questa Sim not Launching
NavneetSingh22
My Laptop has Ubuntu 22.04 running & i am running the Quartus Prime Lite edition 22.1 std bld 1.
Kowing software does not come with model sim, when I launch Questa Simulation i only see the below lines in the command promt and nothing pops up.
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "/home/navneet/intelFPGA_lite/22.1std/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "Test2" "Test2")
Info (22036): For messages from NativeLink execution see the NativeLink log file /home/navneet/Desktop/FPGA_Softwares/Test2/Test2_nativelink_simulation.rpt
I even generated a license file from the self license generating center and added that in the license tab in the Quartus prime tabs, still no luck
Kindly help how to solve this!!.
SyafieqS
Is there any error message when you launch Questasim?
Also can you doubble check if 22.1 fully support Ubuntu 22.04 LTS.
In readme in Quartus path you can see it.
SyafieqS
Let me know if there is any update from previous reply
NavneetSingh22
I was able to run it, it was just getting the right license file the path to be added in the desktop launcher file.
Please close the topic.
thanks  lot for for the support.
SyafieqS
 I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
