- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Dear Support/Expert
I have a Quartus project which compiled no problem, the same code while I try to compile with Questa, I will have some errors. which is not directly related to the source code.
I guess I need someone who familiar with Questa to have a look at this.
the error messsage is
# ** Error: (vopt-31) Unable to unlink file "C:/FPGA/TSW14J57_pro/copy3/prj/mentor/libraries/work/@_opt/_data/exempt30nk3y".
# Permission denied. (errno = EACCES)
Thank you for your help.
David
following are few more lines to provide a context.
# ** Warning: $MODEL_TECH/../intel/verilog/src/mentor/twentynm_atoms_ncrypt.v(40): (vopt-2241) Connection width does not match width of port '<protected>'.<protected>
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(909): (vopt-2685) [TFMPC] - Too few port connections for 'i0_Jesd204b_mc_rx'. Expected 52, found 51.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(909): (vopt-2718) [TFMPC] - Missing connection for port 'jesd204_rx_avs_waitrequest'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(975): (vopt-2685) [TFMPC] - Too few port connections for 'i1_Jesd204b_mc_rx'. Expected 52, found 51.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(975): (vopt-2718) [TFMPC] - Missing connection for port 'jesd204_rx_avs_waitrequest'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(1193): (vopt-2685) [TFMPC] - Too few port connections for 'jesd_dec_xcvr_0'. Expected 48, found 47.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_rx_top.sv(1193): (vopt-2718) [TFMPC] - Missing connection for port 'rx_std_clkout'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(333): (vopt-2685) [TFMPC] - Too few port connections for 'u_tx_transport'. Expected 24, found 20.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(333): (vopt-2718) [TFMPC] - Missing connection for port 'jesd204_tx_link_error'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(333): (vopt-2718) [TFMPC] - Missing connection for port 'csr_n'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(333): (vopt-2718) [TFMPC] - Missing connection for port 'csr_f'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(333): (vopt-2718) [TFMPC] - Missing connection for port 'jesd204_tx_controlin'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(660): (vopt-2685) [TFMPC] - Too few port connections for 'i0_Jesd204b_mc_tx'. Expected 48, found 47.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(660): (vopt-2718) [TFMPC] - Missing connection for port 'somf'.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(733): (vopt-2685) [TFMPC] - Too few port connections for 'i1_Jesd204b_mc_tx'. Expected 48, found 47.
# ** Warning: C:/FPGA/TSW14J57_pro/copy3/ip/ip/jesd204b/jesd204b_jesd_top_qsys_0/jesd_top_qsys_10/sim/jesd_tx_top.sv(733): (vopt-2718) [TFMPC] - Missing connection for port 'somf'.
# ** Warning: (vopt-31) Unable to unlink file "C:/FPGA/TSW14J57_pro/copy3/prj/mentor/libraries/work/@_opt/_data/exempt30nk3y".
# Access is denied. (GetLastError() = 5)
# ** Warning: (vopt-133) Unable to remove directory "C:/FPGA/TSW14J57_pro/copy3/prj/mentor/libraries/work/@_opt/_data".
# ** Warning: (vopt-133) Unable to remove directory "C:/FPGA/TSW14J57_pro/copy3/prj/mentor/libraries/work/@_opt".
# The directory is not empty. (GetLastError() = 145)
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=35, Warnings=2175.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./msim_run.do PAUSED at line 189
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
reboot the computer will solve the problem.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi David,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Why is this an acceptable solution? Aren't we a community of problem solvers? ?This is highlighting an issue with the software.
