When I attempt to start QuestaSim, it will not launch because the path to the executables has not been specified. How do I specify the path?
Hi billviso,
May I know the Quartus edition pro/std/lite?
Sheng
Hi billviso,
For Lite/Std, may go to Tools/Options/EDA Tools Options in Quartus
For Pro, may go to Tools/Launch Simulation Library Compiler
Then, specify the Questasim path:
— On Linux systems: <installation directory>/questa_fe/bin
— On Windows systems: <installation directory>/questa_fe/win64
Questasim Path for starter edition:
— On Linux systems: <installation directory>/questa_fse/bin
— On Windows systems: <installation directory>/questa_fse/win64
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
Hi billviso,
Have your problem been resolved?
Sheng
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
Sheng
