Hi ,
I am trying to compile and run simulation in Questasim , using uvm libraries and uvm packages.
But i am getting error that include files not defined , although these uvm files are installed in verilog_src folder at Questasim installed path.
See screen shots and sv files attached.
Any tip or guide how to direct compiler to pick the installed uvm files.
# three files are :
package file :
`include "uvm_macros.svh"
`include "uvm_pkg.sv"
package uvm_sim_pk;
import uvm_pkg::*;
class my_transaction extends uvm_sequence_item;
`uvm_object_utils(my_transaction)
rand int addr;
rand int data;
rand bit r0w1;
function new (string name = "");
// Without a string name the transaction would be anonymous
super.new(name);
endfunction: new
constraint c_addr { addr >= 0; addr < 256; }
constraint c_data { data >= 0; data < 256; }
endclass: my_transaction
Which specific simulator tool are you using?
Correct me if I am wrong. The tool you are using seems like it is from Siemen Questasim and not the Questa Intel FPGA Edition.
The UVM library is pre-compiled with Questa Intel FPGA Edition.
You may try to consult this at the Siemen forum or you can try download and use our Questa Intel FPGA Edition simulator tool.
Richard Tan
Tool Info:
Questa Intel FPGA Edition-64 2024.1
Revision: 2024.04
HI tried to compile and run using Intel Questasim , but still it wont find uvm macros :
And i can also see that the uvm package files in the linked libraries :
Try using below command with +incdir:
vlog -sv -work work +incdir+$UVM_HOME/src uvm_sim_pk.sv
Make sure $UVM_HOME points to your UVM installation directory.
example:
vlog -sv -work work +incdir+C:/<installation directory>/questa_fe/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
Then vsim example:
vsim -c -sv_lib <installation directory>/uvm-1.1d/win64/uvm_dpi work.my_tb -do "run -all; quit"
You may checkout this webpage for further details:
https://blogs.sw.siemens.com/verificationhorizons/2011/03/08/using-the-uvm-10-release-with-questa/
Do note that the Questa Intel FPGA edition does not support advanced verification features such as randomization. You might see below error message:
# Error: Failure to checkout svverification license feature.
# Fatal: (vsim-7099) Unable to check out a verification license for the randomize() feature.
In that case, you might need to use back the Siemens Questa version. (not Intel/Altera version)
Richard Tan
Hi I tried to compile and include in the working directory , but no success in linking "uvm_macros.svh" .
It is dependent on "uvm_tlm_imps.svh" , which vlog did not complain about , but when i tried to include "uvm_macros.svh" it refers to "uvm_tlm_imps.svh".
Any clue what should be the compile order ? to fix this
See image attached.
Are you using correct command?
I think you should run
vlog -sv -work work +incdir+C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
(there is a space in between uvm_sim_pk.sv and _incdir+C...)
instead of
vlog -sv -work work +incdir+C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/tlml/uvm_tlm_imps.svh
Richard Tan
Any update on this?
Richard Tan
Again, you use the wrong command.
Use:
Not
vlog -sv -work work +incdir+C:\intelFPGA_lite\24.1std\questa_fse\verilog_src\uvm-1.1d\src uvm_sim_pk.sv
That's likely what mess up the path name.
Richard Tan
still its not working , i am getting error msg that questasim cannot open uvm_macros.svh in read mode.
Although i am running questasim in admin mode .
I attached an example that I used.
Add these script into a .do file then run the .do file.
vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src my_transaction.sv
Here is the questasim compile result :
I then changed the do file script to include my modules i.e dut.sv and top.sv like this :
## Questasim do file ##
vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src dut.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src top.sv
in my dut.sv : ------------------------------
import uvm_sim_pkg::*
interface dut_if();
int addr;
int data;
bit r0w1;
modport test (output addr, data, r0w1);
modport dut (input addr, data, r0w1);
endinterface: dut_if
module dut(dut_if.dut i_f);
always @(*)
begin
$display("DUT received r0w1 = %b, addr = %0d, data = %0d at %0t",
i_f.r0w1, i_f.addr, i_f.data, $time);
end
endmodule: dut
in my top.sv : ------------------------------------------------------------------
`include "uvm_sim_pk.sv"
module top;
import uvm_sim_pk::*;
dut_if dut_if1 ();
dut dut1 ( .i_f(dut_if1) );
// Test classes are better placed in a package, but defining the class here
// avoids the need to introduce set_config_db to connect the virtual interface
// in this very simple example
class my_test extends uvm_test;
// my_test gets instantiated by means of the +UVM_TESTNAME command line argument and run_test()
`uvm_component_utils(my_test)
function new(string name, uvm_component parent);
super.new(name,parent);
`uvm_info("", "Called my_test::new", UVM_NONE);
endfunction: new
my_env m_env;
function void build_phase(uvm_phase phase);
super.build_phase(phase);
`uvm_info("", "Called my_test::build_phase", UVM_NONE);
// Always use the factory instead of new
m_env = my_env::type_id::create("m_env", this);
endfunction: build_phase
function void connect_phase(uvm_phase phase);
`uvm_info("", "Called my_test::connect_phase", UVM_NONE);
// Connect virtual interface in driver to actual interface
m_env.m_driver.m_dut_if = dut_if1;
endfunction: connect_phase
task run_phase(uvm_phase phase);
my_sequence seq;
`uvm_info("","Called my_test::run_phase", UVM_NONE);
seq = my_sequence::type_id::create("seq");
assert( seq.randomize() );
seq.start( m_env.m_sequencer );
endtask: run_phase
function void report_phase(uvm_phase phase);
`uvm_info("", "Called my_test::report_phase", UVM_NONE);
endfunction: report_phase
endclass: my_test
initial
// Calls static uvm_env::run_test to execute all test phases for all envs & top-level components
run_test("my_test"); // Requires +UVM_TESTNAME at run-time
endmodule: top
questasim compile results :
i have also tried giving specific path in the .svh file like this :
`include "C:/intelFPGA_lite/24.1std\questa_fse/verilog_src/uvm-1.1d/src/tlm1/uvm_tlm_imps.svh"
`include "C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/uvm_macros.svh"
package sim_pk;
import questa_uvm_pkg::*;
import uvm_pkg::*;
But get this error :
Is the file named uvm_sim_pk.sv (and not uvm_sim_pkg.sv)?
Make sure the package is called uvm_sim_pkg inside the file — the spelling must be exact.
Richard Tan
Any updates on this?
Richard Tan
yes in one module "dut" it was spelled wrong but still compilation results in error of not finding the uvm_pkg .
i have made some changes see below :
//uvm_sim_pk//
`ifndef UVM_SIM_PK
`define UVM_SIM_PK
package uvm_sim_pk;
`include "C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/tlm1/uvm_tlm_imps.svh"
`include "C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/uvm_pkg.sv"
import uvm_pkg::*;
rand int addr;
rand int data;
rand bit r0w1;
super.new(name);
endfunction: new
//top.sv//
module top;
dut_if dut_if1 ();
//dut.sv//
interface dut_if();
import uvm_pkg::*;
int addr;
int data;
bit r0w1;
// do file //
vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_tlm_imps.svh
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_pkg.sv
But i still this error :
Its a UVM guideline to use .sv extensions for compile files and .svh for `include files.
You're trying to compile uvm_tlm_imps.svh directly:
This is incorrect. Remove that line — the uvm_tlm_imps.svh file will be included inside other UVM source files (like uvm_pkg.sv) automatically.
Richard Tan
Any further inquiries regarding this case?
Richard Tan
