17043 Discussions
Reading a file content with quartus
Hi everybody,
I need to read a value from an external file at compilation time and I don´t achieve to do it with quartus. The same code works for Xilinx Ise but I´m not able to do it with Quartus.
The code also works fine with Modelsim.
I have made many changes at code and search solutions on the web but nothing.
This is the begining of the function I use to read the content of the file
use std.textio.all;
-- function to get version from 'version.txt' file
impure function get_version return std_logic_vector is
file data_file: text open READ_MODE is "version.txt";
variable rd_line : line;
begin
-- check that file is not empty
assert(not endfile(data_file))
report "*** ERROR: File is empty" severity error;
-- read 1st line and convert it to string
readline(vers_file, rd_line);
end get_version;
The problem is that I don´t get to read or locate the file. At compilation time it doesn't give me the report error but I know that it does't correctly read the file because if I put a file name it doesn´t exist, It seems to do the same (nothing).
I have been searching for any example, but I didn´t found it. Can anyone help me?
Quartus does not support textio during synthesis whilst Xilinx does. I opened an enhancement request for this about 8 years ago, but still no Textio.
You can get quartus to read in text files using TCL and output a VHDL package that contains the version number.
--- Quote Start ---
--- Quote End ---
Thank you for your answer. I will try to do what you said but I need to do it automatically, so I will try to do a script that firstly generates the VHDL pakage and then compiles and generates all the quartus Project. I hope it is posible.
