Most Altera families have register(s) in the I/O cells. Obviously if I want full control of the plumbing I can instantiate the 'GPIO Lite' IP core and do everything explicitly, but I thought that for simple cases the tools would spot a signal coming in on a pin going straight to a register and use the register in the I/O rather than using up an LE.
However, with my current design it isn't doing that - the fitter resource report says "I/O registers 0/863 (0%)", and looking at the Technology Map viewer I can see my signals coming in through an "IO_IBUF" and then getting latched in a LE. I'm currently working with MAX10 and Quartus Prime 17.0.2 Lite edition (design in VHDL), but I thought I'd seen this working in earlier projects (with Cyclone2/3 and much older versions of Quartus). Am I missing a setting somewhere, or does this feature not exist?Link Copied
If I remember correctly, there is no input register in the IO cell, but a direct connection from the IO cell to the LAB, which is almost as fast. On the output side there should be a 2 registers, because doing DDIO interfaces in the LAB is far too slow(the mux after the registers becomes a LUT to route through and it gets ugly)
Hmm.
According to the manual it certainly has registers ("Max 10 General Purpose I/O user guide", figure 2-1, and in fact I've just checked the old Cyclone III documentation and that has an almost identical diagram of the I/O structure there). That diagram shows a total of 3 registers - one for input, one for output, and one for OE. However, the description says: Each IOE contains one input register, two output registers and two output-enable (OE) registers.- The two output registers and two OE registers are used for DDR applications
- You can use the input registers for fast setup times and output registers for fast clock-to-output times
- You can use the OE registers for fast clock-to-output enable times
It all depends on your timing constraints and if you are using the "Fast I/O register" assignments. Using the registers in the I/O is not always good (and not regularly done by the Fitter) because it's possible to fail hold timing on the I/O to the upstream or downstream device. If you want to force the use of the I/O registers, use a Fast Input or Fast Output register assignment in the Assignment Editor.
Thanks. Enabling "fast input register" for one of my buses certainly got usage of the corresponding number "i/o registers" in the fitter summary, though it's not clear from the netlist viewers whether I had actually got what I had in mind.
So, I gave up on that and decided to do it explicitly with the "Altera GPIO Lite" megafunction. In the megawizard there's not many options exposed: in particular, the clock enable isn't made available. However, the VHDL it generates has all sorts of features:
component altera_gpio_lite is
generic (
PIN_TYPE : string := "output";
SIZE : integer := 4;
REGISTER_MODE : string := "bypass";
BUFFER_TYPE : string := "single-ended"
ASYNC_MODE : string := "none";
BUS_HOLD : string := "false";
OPEN_DRAIN_OUTPUT : string := "false";
ENABLE_OE_PORT : string := "false";
ENABLE_NSLEEP_PORT : string := "false";
ENABLE_CLOCK_ENA_PORT : string := "false";
SET_REGISTER_OUTPUTS_HIGH : string := "false";
INVERT_OUTPUT : string := "false";
INVERT_INPUT_CLOCK : string := "false";
USE_ONE_REG_TO_DRIVE_OE : string := "false";
USE_DDIO_REG_TO_DRIVE_OE : string := "false";
USE_ADVANCED_DDR_FEATURES : string := "false";
USE_ADVANCED_DDR_FEATURES_FOR_INPUT_ONLY : string := "false";
ENABLE_OE_HALF_CYCLE_DELAY : string := "true";
INVERT_CLKDIV_INPUT_CLOCK : string := "false";
ENABLE_PHASE_INVERT_CTRL_PORT : string := "false";
ENABLE_HR_CLOCK : string := "false";
INVERT_OUTPUT_CLOCK : string := "false";
INVERT_OE_INCLOCK : string := "false";
ENABLE_PHASE_DETECTOR_FOR_CK : string := "false"
port (
inclock : in std_logic := 'X';
dout : out std_logic_vector(7 downto 0);
pad_in : in std_logic_vector(7 downto 0) := (others => 'X');
inclocken : in std_logic := 'X';
fr_clock : out std_logic_vector(7 downto 0);
hr_clock : out std_logic;
invert_hr_clock : in std_logic := 'X';
outclock : in std_logic := 'X';
outclocken : in std_logic := 'X';
phy_mem_clock : in std_logic := 'X';
mimic_clock : out std_logic_vector(7 downto 0);
din : in std_logic_vector(7 downto 0) := (others => 'X');
pad_io : inout std_logic_vector(7 downto 0) := (others => 'X');
pad_io_b : inout std_logic_vector(7 downto 0) := (others => 'X');
pad_in_b : in std_logic_vector(7 downto 0) := (others => 'X');
pad_out : out std_logic_vector(7 downto 0);
pad_out_b : out std_logic_vector(7 downto 0);
aset : in std_logic := 'X';
aclr : in std_logic := 'X';
sclr : in std_logic := 'X';
nsleep : in std_logic_vector(7 downto 0) := (others => 'X');
oe : in std_logic_vector(7 downto 0) := (others => 'X')
end component altera_gpio_lite;
I then tried instantating this by hand in my VHDL, setting "ENABLE_CLOCK_ENA_PORT" to "true", "REGISTER_MODE" to "single-register" and wiring up the relevant ports. This again gave sensible resource usage reports when compiled, but looking at the netlist viewer it seemed to have ignored my clock enable. So I am reluctantly concluding that this stuff is half-baked (at least in respect of Max10) - not clear whether the deficiencies lie in the tools, the documentation (describing features that don't exist), or the silicon (tools disabled because features don't work?).
