Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Remove "unknown" pins in the Pin Planner
Does exist some option that allows to remove all "unknown" pins in the Pin Planner?
Actually after removing a set of signal (e.g. bus) in the top unit port declaration, I need to remove concerned signals step-by-step (and with confirmation).
Quite annoying ...
Just shift or control click them to select them then delete.
As I remember, it doesn't work just in one time: removing of a particular pin requires confirmation.
I believed that does exists some dedicated option ... something like "Remove unknown pins assignment".
