Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Replace PLL settings with new one
Simple Q, I hope - I'm just starting out with Altera & Quartus.
I've successfully added an ALTPLL from the IP Catalog to my project (Quartus Prime 16.0 Lite, Linux).
Now I'd like to re-synthesise with a different c0 setting, to run at 150 iso 100 MHz.
How do I do this in the IDE without re-entering all the settings and completely overwriting what I have?
-jcw
Highlighted
you can just double-click the PLL component in the project navigator; the IP dialog will pop up again, will all your settings still there. Modify what you want, finish the dialog, re-synthesize.
GooGooCluster
Highlighted
Unfortunately, when I try that, the file opens as text in an editor.
Ah, wait - I was using the "Files" view.
In Hierarchy tree mode, the plugin manager opens.
Mystery solved. Thanks very much!
-jcw
