quartus ii version before 10.0 can display resource usage of each module in the hierarchy window, just need to right click and select custom the column.
but i find these feature is lost in quartus 10.1, so i have to find that info in fitter report. Would altera pls add that feature in later version?Link Copied
Hi
is there any way to export it to file (report kind)? BR Meir- Mark as New
All the information is in the fit report.
Anyway, what's the TLC command, which could be used in order to generate the Utilization Report by Hierarchy?
