I've just installed the QUARTUS II, and i am trying to run a simulation because i'm receiving the message below, can i have help solving this please? thanks
Device family: MAX7000S
Running quartus eda_testbench
>> quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog test -c test {--vector_source=C:/Users/tracy/Documents/test/Waveform.vwf} {--testbench_file=./simulation/qsim/test.vt}
PID = 8580
Running Quartus II 64-Bit EDA Netlist Writer
Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version
Processing started: Tue Dec 26 18:51:19 2017
Command: quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog test -c test --vector_source=C:/Users/tracy/Documents/test/Waveform.vwf --testbench_file=./simulation/qsim/test.vt
Generated Verilog Test Bench File ./simulation/qsim/test.vt for simulation
Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 0 warnings
Peak virtual memory: 375 megabytes
Processing ended: Tue Dec 26 18:51:21 2017
Elapsed time: 00:00:02
Total CPU time (on all processors): 00:00:02
Running quartus eda_func_netlist
>> quartus_eda --functional=on --simulation --tool=modelsim_oem --format=verilog test -c test
PID = 14608
Processing started: Tue Dec 26 18:51:22 2017
Command: quartus_eda --functional=on --simulation=on --tool=modelsim_oem --format=verilog test -c test
Generated file test.vo in folder "C:/Users/tracy/Documents/test/simulation/modelsim/" for EDA simulation tool
Processing ended: Tue Dec 26 18:51:23 2017
Elapsed time: 00:00:01
Running quartus modelsim
>> vsim -c -do test.do
PID = 9300
Reading C:/altera/13.0sp1/modelsim_ase/tcl/vsim/pref.tcl
# 10.1d
# do test.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling module test
# Top level modules:
# test
# -- Compiling module test_vlg_sample_tst
# -- Compiling module test_vlg_check_tst
# -- Compiling module test_vlg_vec_tst
# test_vlg_vec_tst
# vsim -L max7000s_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate -c -t 1ps -novopt work.test_vlg_vec_tst
# Loading work.test_vlg_vec_tst
# ** Error: (vsim-19) Failed to access library '/../altera/verilog/max' at "/../altera/verilog/max".
# No such file or directory. (errno = ENOENT)
# Loading work.test
# ** Error: (vsim-3033) test.vo(71): Instantiation of 'max_io' failed. The design unit was not found.
# Region: /test_vlg_vec_tst/i1
# Searched libraries:
# c:/altera/13.0sp1/modelsim_ase/altera/verilog/altera
# c:/altera/13.0sp1/modelsim_ase/altera/verilog/altera_mf
# c:/altera/13.0sp1/modelsim_ase/altera/verilog/220model
# c:/altera/13.0sp1/modelsim_ase/altera/vhdl/sgate
# C:/Users/tracy/Documents/test/simulation/qsim/work
# ** Error: (vsim-3033) test.vo(84): Instantiation of 'max_io' failed. The design unit was not found.
# ** Error: (vsim-3033) test.vo(97): Instantiation of 'max_io' failed. The design unit was not found.
# ** Error: (vsim-3033) test.vo(123): Instantiation of 'max_mcell' failed. The design unit was not found.
# ** Error: (vsim-3033) test.vo(148): Instantiation of 'max_mcell' failed. The design unit was not found.
# ** Error: (vsim-3033) test.vo(160): Instantiation of 'max_io' failed. The design unit was not found.
# ** Error: (vsim-3033) test.vo(173): Instantiation of 'max_io' failed. The design unit was not found.
# Loading work.test_vlg_sample_tst
# Loading work.test_vlg_check_tst
# Error loading design
Check the below thread which discuss on same issues. https://alteraforum.com/forum/showthread.php?t=44213 To work around this problem, perform the following steps Make the file <Quartus II installation directory>\modelsim_ase\modelsim.ini writable. For example on Windows, right-click the file, select properties from the context menu and turn off the read-only option Add the following line to modelsim.ini: max7000s = /../altera/verilog/max Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
