16636 Discussions
SOPC custom component: no license?
I am trying to run sopc-builder from the command line under linux (in a vm because it ain't working in vista). It's working great (ask me if you want details), except that when I try to use a custom component I get the following:
Warning: DDR_inst: Used DDR 1.0 (instead of 7.8)
Progress: current 425:
Progress: Adding connections
Progress: current 545:
Progress: Adding clock domains
Progress: Validating SOPC
Progress: current 1745:
Progress: Done
Progress: Validating...
Progress: Generating /root/Desktop/Alex/Projects/D.D.Raucous/Prototype_CS__v0.2.0/IP/SOPC.sopc
Error: DDR_inst: Error: License file is not specified
Error: Generation skipped because the system has validation errors.
What's it talking about? How can i specify a license file for my custom component?
Does your "Custom" component use the have the same name of a "Licensed" DDR component? It looks like it might have pulled the stock SOPC DDR controller instead of your version..
(Used DDR 1.0 (Instead of 7.8)) message..
If you have a true custom component with RTL sources, you shouldn't require a license file for it. (You will require a license file for NIOS, etc)
If you have a USB dongle, that the license is hooked to you will have to use a Windows based version of Quartus, The linux version only works with floating FLexLM licenses as far as I know.. (At least around version 6.1 time frame)
Pete
That's a good idea but it wasn't it. Do you know where the license files for altera's components are/how they're specified? Maybe you know which script is being run, so I can look at the sources?
Btw, what I'm doing is using the Windows SOPC Builder to save a .sopc file, and then using the linux command sopc-builder --generate <file>.sopc. This flow works when using non-custom components. Note: I don't have a quartus license so I can't use the GUI in linux to try the "normal" flow, but like I said it works like this.
Hi Alex.. Sorry Don't know how altera handles it's licenses. I know for "Licensed" components it ends up being a line in the license file.
My guess is having the "custom" component probably caused sopc builder to look for a general Altera custom component license line.. which is probably just part of the normal license file.
Pete
I made an a blank file and pointed LM_LICENSE_FILE to it. It worked!!
Thank you!
