Can somebody check this for me as I've replicated it in two installs now and it is driving me mad...
When editing a files in Quartus I frequently use shift + cursor keys to select text. In Quartus 12.1 and earlier, this worked fine as it does in very many other programs. In Quartus 13.0, I find that I can only select a single line this way. Trying to select multiple lines doesn't. If somebody else gets the same, let us know and I'll file a bug report. Thanks. edit --- Add to this, select a section of text and press ctrl and it deselects. Bit of a pain when you want to ctrl c / ctrl x....Link Copied
and today it appears to be working fine.....
I have the same problem one day there is the problem another day no!!!Fantastic!!!
Solution, use a better text editor. You can even setup quartus to open files in the external editor. Notepad++ is good and free
Just had it happen to me again. A restart of Quartus sorted it.
I do use Notepad++ for all sorts of stuff but not normally when using Quartus. I've just switched it on - I'm not sure though if it is for me.- Mark as New
I actually prefer ultraedit to notepad++, but its not free. Notepad ++ is the best free alternative (IMO)
I prefer textpad over the quartus editor.
Topic Options
