16704 Discussions
Signal tap: Program the device to continue
BeB
I am using Quartus 19.1 for a Stratix S10 1SX280LN3. After successfully compiling my project with the latest .stp file created from signal tap analyzer (no warnings other than some registers pruned away) and programming the device, I keep getting the message "program the device to continue" when launching signal tap. Of course if I program the device, I keep getting the same message.
That makes it impossible to debug my project.
Many thanks for any input you may have,
BeB
sstrell
That status message isn't always 100% accurate, especially if you program the device in the Programmer instead of directly from the JTAG Configuration section of the .stp file window.  Just try starting the logic analyzer after programming the device.  If it works, great.  If not, you may get a message about why it won't run.
BeB
Thanks for the feedback. The same issue arises whether I use the programmer or directly program the .sof from the signal tap analyzer window.
On top of that, I would like to enable signal tap to debug some faulty behavior at power up that happens once in a while, therefore I do not want to re-program the device once the faulty behavior happens.
Thanks again,
BeB
sstrell
For that, you need to set up a power-up trigger that does exactly what you need: look for a trigger event to occur after device programming but before you can manually start the logic analyzer.  See the debug tools user guide for details on setting up a power-on trigger.
BeB
Yes I am aware, but that doesn't work when the message "program the device to continue" is displayed. I am sure the trigger worked, but I can't get the data from signal tap.
sstrell
Are you programming in the .stp window or in the Programmer?
If you are successfully programming the device from within the .stp window and you are still seeing that status, which is preventing you from starting the logic analyzer to obtain the power-up trigger captured data, the only thing I can think of is recompile and generate a new programming file.
BeB
I have done both (.stp window and programmer), with the same result. I have tried recompiling, without success.
One of the major change introduced between the working signal tap and broken signal tap is the clocking scheme. I selected a new reference clock in signal tap to reflect that, it's a valid reference clock as far as I know, but maybe signal tap disagrees with that assessment? Mind you, the project is completely functional otherwise.
I can't really think of anything else.
BeB
RichardTanSY_Intel
Regarding to the issue "Program the device to continue", you may checkout the webpage below for solution.
https://www.programmersought.com/article/27694462090/
I hope it helps.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
BeB
Thank you for your input, but the cable is definitely plugged since I can flash the device, and the device has not changed, it's always been the same (and the correct one) and it used to work just fine.
BeB
RichardTanSY_Intel
Hi @BeB
I can't figure out what could go wrong for your issue.
One thing to try is to reduce the clock frequency. That may help with detecting the signal taps.
You could try to install the latest Quartus Pro 21.1 and check if the issue still persist.
Richard Tan
RichardTanSY_Intel
I have yet to receive any response from you to the previous question/reply/answer that I have provided.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
DeanK77
This exchange was useless.
