17124 Discussions
Signal tap not working in Quartus Pro 18.0
ASvir2
Hi all!
I'm working on a design for a custom board with Cyclone 10 GX FPGA.
I am able to program the design using jtag, but I'm unable to use Signal Tap (there's "instance not found" message under status).
I downloaded .sof for sure because I see leds toggling, in fitter report signal tap uses some resources and it's enabled in project settings.
Did anyone else have this issue?
I'm using Quartus Pro 18.0.
Thank you.
ASvir2
Just a quick update, I managed to solve my problem by changing the jtag clock frequency on usb blaster II from 24 MHz to 6MHz.
